compact carrier for Kossel Deltas October 31, 2017 01:17PM |
Re: compact carrier for micro Deltas October 31, 2017 01:31PM |
Re: compact carrier for micro Deltas October 31, 2017 01:49PM |
Re: compact carrier for micro Deltas October 31, 2017 02:31PM |
Re: compact carrier for micro Deltas November 01, 2017 03:09AM |
Re: compact carrier for micro Deltas November 01, 2017 12:57PM |
Re: compact carrier for micro Deltas November 01, 2017 02:32PM |
Re: compact carrier for micro Deltas November 01, 2017 09:05PM |
IGUS website has a nice engineering guide for polymer bushings and distances to sliding points and pulling points to eliminate stiction, I think this is not the link I used the graphic is different but the information is the same and there is other information as well.|
Re: compact carrier for micro Deltas November 02, 2017 03:40AM |
Re: compact carrier for micro Deltas November 02, 2017 04:58AM |
would work for bigger Kossel Deltas as well. The gain of a few extra mm in workspace/printersize is neglectible, but placing rod ends, belts and sliders closer together sure is an advantage to consider. ( and it looks cleaner with invisible belts, too
Re: compact carrier for Kossel Deltas November 02, 2017 10:54AM |
Re: compact carrier for Kossel Deltas November 02, 2017 02:36PM |
Re: compact carrier for Kossel Deltas November 03, 2017 05:03PM |
Re: compact carrier for Kossel Deltas November 04, 2017 01:01PM |
Re: compact carrier for Kossel Deltas November 05, 2017 11:59AM |
Re: compact carrier for Kossel Deltas November 06, 2017 02:09AM |
Re: compact carrier for Kossel Deltas November 18, 2017 09:37AM |
Re: compact carrier for Kossel Deltas November 18, 2017 09:57AM |
Re: compact carrier for Kossel Deltas November 20, 2017 12:00AM |
Re: compact carrier for Kossel Deltas November 20, 2017 03:28AM |
Re: compact carrier for Kossel Deltas November 20, 2017 03:45AM |
Re: compact carrier for Kossel Deltas November 21, 2017 03:04AM |
Re: compact carrier for Kossel Deltas November 21, 2017 05:28AM |
Re: compact carrier for Kossel Deltas November 21, 2017 05:38AM |
Re: compact carrier for Kossel Deltas November 21, 2017 05:50AM |
Re: compact carrier for Kossel Deltas November 21, 2017 06:33AM |
Re: compact carrier for Kossel Deltas November 21, 2017 07:28AM |
Re: compact carrier for Kossel Deltas November 22, 2017 02:25AM |
Re: compact carrier for Kossel Deltas November 22, 2017 03:48AM |
Re: compact carrier for Kossel Deltas November 22, 2017 04:33AM |
DjDemonD
I will probably get critiqued for this, but with my PCB carriages on my kossel XL, I do not have robotdigg carriages or anything like that on top of them, that's unnecessary complexity and mass. One of the 4 screw holes in the linear rail carriage now sports a 25mm M3 screw, which both sides of my belt are fixed to, with a twist for the top pulleys, so that as DC said the tension is carried by the belt. Ill append an image later.
As for tensioning, I have printed inline tensioners, which work great on deltas as there is so much "spare" belt below the carriages which does not interfere with anything in use that you don't get on corexy's/cartesians, although I'd like to use them there also, as its just one twist of a screw to tension.
[attachment 99816 20171121_22265601.jpg]
