Trouble with swelling part corners December 18, 2017 10:40AM |
Re: Trouble with swelling part corners December 18, 2017 12:26PM |
Re: Trouble with swelling part corners December 18, 2017 03:34PM |
Re: Trouble with swelling part corners December 19, 2017 03:09AM |
Re: Trouble with swelling part corners December 20, 2017 06:32AM |
dc42
It looks like over-extrusion to me. Have you calibrated the extruder steps/mm ?
SDM
Hi
The jerk on the extruder seems really low, 13 mm/min is only .217 mm/sec. I run a direct drive extruder and have the jerk set to 600 mm/min.
I got really terrible prints when the jerk was set too low.
o_lampe
Were you able to tighten the steel core belts good enough? It could be overshooting from loose belts. Others have reported, the steel core belt also needs bigger dia. pulleys to run smooth.
Re: Trouble with swelling part corners December 20, 2017 04:56PM |
Re: Trouble with swelling part corners December 21, 2017 05:38AM |
Re: Trouble with swelling part corners December 21, 2017 06:24AM |
Re: Trouble with swelling part corners December 21, 2017 07:19AM |
Re: Trouble with swelling part corners December 21, 2017 09:15AM |
Re: Trouble with swelling part corners December 22, 2017 04:19AM |
