DemonDeltaTube - A delta inside an acrylic tube... Build December 29, 2017 05:22PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build December 29, 2017 05:41PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build December 29, 2017 09:59PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build December 30, 2017 03:12AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build December 30, 2017 03:54AM |
etfrench
I don't think you need to have the linear rails at 90 degrees to the bed. Delta software should be able to handle the offset.
Re: DemonDeltaTube - A delta inside an acrylic tube... Build December 30, 2017 04:13AM |
) One template for the bottom and top, properly aligned would've worked too...|
Re: DemonDeltaTube - A delta inside an acrylic tube... Build December 30, 2017 04:14AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 01, 2018 10:38AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 02, 2018 03:25AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 02, 2018 04:57AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 03, 2018 04:25PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 04, 2018 03:55AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 04, 2018 04:01AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 04, 2018 11:53AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 04, 2018 12:13PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 04, 2018 12:55PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 04, 2018 01:57PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 04, 2018 04:50PM |
DjDemonD
One of the towers was about 5 degrees out of position. I appreciate RRF software can compensate but I might be asking a lot.
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 04, 2018 04:59PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 05, 2018 10:13AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 05, 2018 12:10PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 06, 2018 12:03PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 09, 2018 02:33AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 27, 2018 06:00PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 28, 2018 03:05AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 28, 2018 05:05AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 28, 2018 11:03AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 29, 2018 03:07AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 29, 2018 05:56AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 29, 2018 01:06PM |
