iKessel - Kossel XL with ikea enclosure January 01, 2018 09:45PM |
Re: iKessel - Kossel XL with ikea enclosure January 01, 2018 09:48PM |
Re: iKessel - Kossel XL with ikea enclosure January 02, 2018 03:20AM |
Re: iKessel - Kossel XL with ikea enclosure January 02, 2018 09:15AM |
dc42
Very nice! I might try that myself.
What are you using to attach the flying extruder to the carriages, and what are the red printed parts at the bottom of the towers for?
You might want to print covers for the mains terminals on the SSR and the power supply.
Re: iKessel - Kossel XL with ikea enclosure January 02, 2018 11:06AM |
Re: iKessel - Kossel XL with ikea enclosure January 02, 2018 01:50PM |
Re: iKessel - Kossel XL with ikea enclosure January 02, 2018 10:33PM |
o_lampe
I was wondering if "Britax" water filter are any good for enclosure ventilation?
Re: iKessel - Kossel XL with ikea enclosure January 03, 2018 12:00AM |
Re: iKessel - Kossel XL with ikea enclosure January 03, 2018 12:12AM |
Re: iKessel - Kossel XL with ikea enclosure January 03, 2018 03:37AM |
Re: iKessel - Kossel XL with ikea enclosure January 04, 2018 12:09PM |
Vigilant
[attachment 101124 Heatedchamber.JPG]
Hmm I've been thinking on how to make a heated build chamber as simple as possible with my current setup. I have a 500W silicon heater and I thought i could probably use that as the heating element instead of a separate one.
A blower blows the air below the heated bed. A PID control loop controls the PWM of the blower fan based on the thermistor temperature connected to E1. Seems simple enough without needing additional hardware.
I only want the chamber to be in the 45-50c region so I think my 500W bed should have some spare power to heat up the whole chamber. The heated bed will be at 90-100C so it sounds like it should be doable.
Re: iKessel - Kossel XL with ikea enclosure January 04, 2018 07:38PM |
Origamib
Vigilant
So you are cooling one heat source in order to maintain the heat of another?
Re: iKessel - Kossel XL with ikea enclosure January 05, 2018 04:14PM |
Vigilant
Origamib
Vigilant
Yup which means the heated bed is forced to work harder to heat both sides.
Re: iKessel - Kossel XL with ikea enclosure January 06, 2018 10:59AM |
Teilchen
Vigilant
Origamib
Vigilant
I have a similar setup with my enclosed printer (using acrylic pannels). I have a 350W heater and a couple of fans blowing the air from the electronics compartment through the base cover. I am getting about 40C inside the housing, and that's considering a 350W and very bad isolation. So I think 500W will do well. I do have a thermal isolation on the back of my bad heater though, just to make sure I will not cool the bed down.
Would you care to share the links for the IKEA stuf? I am not an IKEA specialist , so it is very hard to find the things you described.
Re: iKessel - Kossel XL with ikea enclosure January 06, 2018 11:17AM |
Re: iKessel - Kossel XL with ikea enclosure January 08, 2018 03:32AM |
Re: iKessel - Kossel XL with ikea enclosure January 16, 2018 08:51PM |
