Does RADDS have the right pins to support a Smart Effector PCB? February 14, 2018 04:57PM |
Re: Does RADDS have the right pins to support a Smart Effector PCB? February 15, 2018 12:31AM |
Re: Does RADDS have the right pins to support a Smart Effector PCB? February 15, 2018 03:55AM |
Re: Does RADDS have the right pins to support a Smart Effector PCB? February 15, 2018 05:37AM |
o_lampe
In order to use X-max endstop, you'd have to use the stall detection method for homing.
On RADDS there is only one pin for z-probes: PWM3, but on Duet I have to use E0-stop for proximity sensors and the Z-probe connector for the Smart Effector. Are they the same?
// Endstops
// E Stops not currently used
// Note: RepRapFirmware only as a single endstop per axis
// gcode defines if it is a max ("high end") or min ("low end")
// endstop. gcode also sets if it is active HIGH or LOW
// 28 = RADDS X min
// 30 = RADDS Y min
// 32 = RADDS Z min
// 39 = RADDS PWM3
// This leaves 34, 36, and 38 as spare pins (X, Y, Z max)
const Pin END_STOP_PINS[DRIVES] = { 28, 30, 32, 39, NoPin, NoPin, NoPin, NoPin };
// Z Probe pin
// Must be an ADC capable pin. Can be any of the ARM's A/D capable
// pins even a non-Arduino pin.
const Pin Z_PROBE_PIN = 5; // RADDS "ADC" pin
// Digital pin number to turn the IR LED on (high) or off (low)
// D34 -- unused X-max on RADDS
const Pin Z_PROBE_MOD_PIN = 34;
Re: Does RADDS have the right pins to support a Smart Effector PCB? February 15, 2018 02:50PM |
