New delta design with fixed ballscrews March 06, 2018 01:34AM |
Re: New delta design with fixed ballscrews March 06, 2018 03:02AM |
Re: New delta design with fixed ballscrews March 06, 2018 03:10AM |
Re: New delta design with fixed ballscrews March 06, 2018 03:12AM |
frankvdh
Why not have the steppers rotate the screws? That way you aren't moving the mass of the motors, and the motor wiring doesn't need to move either. Motors attached to the top plate, and some 608ZZ or similar bearings in the bottom.
Re: New delta design with fixed ballscrews March 06, 2018 03:41AM |
Re: New delta design with fixed ballscrews March 06, 2018 10:19PM |
Re: New delta design with fixed ballscrews March 07, 2018 01:58AM |
Trakyan
I don't see the fuss about trying to keep the motor stationary, I'm guessing a screw that big has more inertia when spun up than the motor does when it has to move itself. I agree it means less wiring, but that may not be the goal here.
This is similar to the LISA Simpson Nicholas Seward built a while back. You can let the nut/carriage assembly rotate if you don't use parallel links to the effector. All you have to do is compensate for that rotation (and the translation along the ballscrew's axis it causes) in your kinematics. Not necessarily fun, but doable.
Re: New delta design with fixed ballscrews March 08, 2018 06:18AM |
Re: New delta design with fixed ballscrews March 08, 2018 07:07AM |
Re: New delta design with fixed ballscrews March 08, 2018 11:21AM |
DjDemonD
I like the idea of the motors moving as its novel and whilst at first it might seem unnecessary, some benefits may emerge so its worth trying. My main concern is that your leadscrews will never be straight enough to prevent horrible wobble as you move up and down the axes. So you'll need to add a linear rail or rods or something in addition to the screws. Which begs the question could you use the screw and linear rail to supply positive and negative power and then have wireless stepper driver units on the motor carriages?
Re: New delta design with fixed ballscrews March 08, 2018 01:05PM |
Re: New delta design with fixed ballscrews March 08, 2018 02:22PM |
Re: New delta design with fixed ballscrews March 08, 2018 02:24PM |
DjDemonD
Maybe there's a way to encode the position information onto the power lines like homeplug type systems. On the other hand maybe some wires to the motors isn't that much of a problem.
Re: New delta design with fixed ballscrews March 08, 2018 04:13PM |
klcjr89
DjDemonD
Another way would be to have a PCB with four copper tracks on it, and make an adapter that plugs into the stepper's port that has spring loaded contact pogo pins. There would be one PCB per stepper motor. The pogo pins will make contact with the tracks as each carriage moves up and down.
Re: New delta design with fixed ballscrews March 08, 2018 04:15PM |
MKSA
klcjr89
DjDemonD
How about using linear motors, the tracks being the vertical guides ?
And all this in a closed vacuum tube. It would be called the HyperDelta printing at 10^6 mm/s
: [www.mcmaster.com]|
Re: New delta design with fixed ballscrews March 09, 2018 03:23AM |
Linear motors are too expensive, I explored that last year getting quotes from companies, namely H2W (they cost as much as a car).
If we could figure out how to make them at home, that would be great. The platens can be sourced from McMaster-Carr using precision ground raw material, but they will need 'teeth' cut/ground in to them at a precise pitch. The forcer is a 2 phase electromagnet with ball-bearings that maintain a correct air gap.
Re: New delta design with fixed ballscrews March 09, 2018 04:02AM |
Re: New delta design with fixed ballscrews March 09, 2018 04:32AM |
DjDemonD
If you can make a linear motor that would be awesome. But... Isn't the point to get rid of wires, if the forcer is still in the carriage then you'll have to run cables to it.
No risk of a cow crossing so ?|
Re: New delta design with fixed ballscrews March 09, 2018 04:34AM |
Re: New delta design with fixed ballscrews March 09, 2018 12:13PM |
o_lampe
How deep are the teeth? Would it be possible to etch them?
DjDemonD
I was thinking have the coils in the track and permanent magnets in the carriage.
Re: New delta design with fixed ballscrews March 09, 2018 03:55PM |
Re: New delta design with fixed ballscrews March 09, 2018 03:57PM |
MKSA
BTW, I proposed this linear motor to tease you ! Have you seen and used them ? There is no way you could make them at home. They also run on an air cushion.
In fact, it could be used but as an X Y moving table, you put the bed on it and just need a hotend moving just in Z. A good start, this one: [www.ebay.com]
Re: New delta design with fixed ballscrews March 10, 2018 02:51AM |
Re: New delta design with fixed ballscrews March 10, 2018 03:43AM |
klcjr89
MKSA
Actually, the air cushion ones are a different model, the ball bearings ones would work just fine, and I do have experience with them. You could make them at home with a surface grinder and a milling machine. [www.h2wtech.com]
Re: New delta design with fixed ballscrews March 10, 2018 11:33AM |
o_lampe
In which way are these small bearings better than V-wheels and belt? You'd also need more bearings than shown, as you are moving vertical with no gravity holding the forcer down.
MKSA
So, lead screws or linear motors ?
but maybe a seperate thread should be made for them to see how to pull it off so other printers can benefit from it.|
Re: New delta design with fixed ballscrews March 10, 2018 03:37PM |
