My First Delta Printer build March 11, 2018 03:19PM |
Re: My First Delta Printer build March 13, 2018 03:37AM |
Re: My First Delta Printer build March 13, 2018 05:51AM |
Re: My First Delta Printer build March 13, 2018 09:44AM |
o_lampe
I'm not a Delta guru or shaman, but to me your rods look too long. You'll loose a lot of print height that way.
My way of calculating the rod length is based on the 20° rule:
Rod length = bed diameter / cos(20)
Then add some mm for safety margin.
Re: My First Delta Printer build March 13, 2018 10:01AM |
dc42
1. As @o_lampe says. When the nozzle is at the edge of the printable area opposite a tower, the angle of the rods to that tower should be no less than 20 degrees to the horizontal, preferably 25. In your last image it looks more like 40 degrees.
2. Choose the lead of the ballscrews carefully to get the steps/mm in the right range. The absolute lowest you should aim for is 80 microsteps/mm @ x16 microstepping; but if you are prepared to pay for good electronics and use 24V power then 200 microsteps/mm @ x16 microstepping will give you better print quality. You can select either 0.9 or 1.8deg motors to help get the steps/mm in the right range. When you think you have a good choice of ballscrews and motors, use the calculator at [reprapfirmware.org] to work out whether you can achieve your target speed. Belt-driven deltas can usually achieve high speeds, and you won't want to sacrifice that advantage because of your choice of ballscrews. 200mm/sec is a good figure to aim for.
3. As your motors will be at the top, IMO it makes sense to put the electronics at the top too because it simplifies the wiring. So consider using a SSR to switch the bed heater, with the PSU and SSR under the bed. That avoids running high power cables between top and bottom of the printer.
Re: My First Delta Printer build March 13, 2018 11:22AM |
Re: My First Delta Printer build March 13, 2018 04:11PM |
dc42
Dual nozzles on deltas are tricky because of the need to keep the nozzles at exactly the same height. Single nozzle using a switching or mixing hot end is more practical, but comes with its own issues. As it's your first printer, I suggest you built it single extrusion to start with, but design the effector size to be able to accommodate a switching/mixing hot end if you wish.
See [duet3d.dozuki.com] for a list of mechanical aspects that you need to get right to close tolerances when building a delta printer. One way of getting some of these right and doing bed probing is to use the Smart Effector, [duet3d.dozuki.com].
Re: My First Delta Printer build March 13, 2018 07:12PM |
Re: My First Delta Printer build March 14, 2018 12:03AM |
Re: My First Delta Printer build March 14, 2018 03:15AM |
dc42
For delta printers, it's important to get the Z probe as close to the nozzle as possible, or (preferably) to use the nozzle itself as the probe.
Re: My First Delta Printer build March 14, 2018 03:27AM |
Vigilant
You should worry more on frame rigidity , repeatabilty, reliability and accuracy of your config values . Delta maths are handled by firmware not you, so you shouldn't worry about it.
Re: My First Delta Printer build March 22, 2018 05:13PM |
Re: My First Delta Printer build June 11, 2018 12:58PM |
