Hi all, i'm trying to use a bltouch on a anycubic delta plus linear with marlin 1.1.8 but G33 probe outside the bed and seem to not use value from
#define X_PROBE_OFFSET_FROM_EXTRUDER 35 // X offset: -left +right [of the nozzle]
#define Y_PROBE_OFFSET_FROM_EXTRUDER 20 // Y offset: -front +behind [the nozzle]
#define Z_PROBE_OFFSET_FROM_EXTRUDER -3.10 // Z offset: -below +above [the nozzle],
a can reduce area but test will only on a small surface on the right.... how i can change offset of G33 command and check more or less all the bed ?
