My first delta 3D printer May 01, 2018 01:27PM |
Re: My first delta 3D printer May 01, 2018 01:43PM |
Re: My first delta 3D printer May 01, 2018 01:52PM |
Re: My first delta 3D printer May 01, 2018 01:57PM |
Re: My first delta 3D printer May 02, 2018 03:19AM |
I think I'll use Bondtech extruders because I like that they push from both sides.
Re: My first delta 3D printer May 02, 2018 03:30AM |
o_lampe
I don't have experience with these, but IMHO the second drive gear is pure marketing bull$hit. It would be much better, if it had it's own motor. But now it's just a "follower" which adds friction losses and the motor invests more torque to bite into the filament instead of pushing it.
Re: My first delta 3D printer May 02, 2018 05:47AM |
dc42
o_lampe
As I understand it, the drive second gear isn't a follower, instead both drive gears are driven from the motor via 3:1 gearing. The motor won't necessarily need to invest more torque to bite into the filament, because to get the same force on the filament each drive gear will not need to bite into the filament as much as if there was just a single drive gear. In any case, 3:1 geared extruders driving 1.75mm filament are not normally short of motor torque.
I ordered a Bondtech BMG yesterday. When it arrives I will compare it with the Titan that I currently use on that printer.
Re: My first delta 3D printer May 02, 2018 12:30PM |
Vigilant
dc42
Do post a comparison and review. Will you be using it as a flying extruder , bowden or direct drive?
Re: My first delta 3D printer May 02, 2018 05:02PM |
