autoleveling plus mesh-bed compensation August 30, 2018 10:16PM |
Re: autoleveling plus mesh-bed compensation August 31, 2018 05:11PM |
Re: autoleveling plus mesh-bed compensation September 02, 2018 09:36PM |
Re: autoleveling plus mesh-bed compensation September 04, 2018 12:58AM |
Re: autoleveling plus mesh-bed compensation September 05, 2018 06:48AM |
Re: autoleveling plus mesh-bed compensation September 06, 2018 02:33PM |
Ummm, isn't RMS always lower than the peak values?Quote
RMS, but as you can imagine the peak is very low
How do you use more than 3 points to adjust a stiff plate? My bed is a 1/4" MIC-6 cut with a waterjet (so residual stresses should be pretty low).Quote
admittedly the 8mm thick 400mm round tooling plate with 7 manual height adjustment points and a 4mm borosilicate plate on top goes a long way to achieving this
It's been a real challenge to 'square' my printer with so many 60 deg angles, especially the diagonals or towers that lean sideways.Quote
laser squared the printers and put on adjustable feet, then sit them on individual 20mm thick steel plates that are also on adjustable feet and have been levelled and I am running 0.9* motors and custom 16 tooth pulleys with additional tension pulleys to ensure I have the accuracy in movement and control over the belt backlash.
Re: autoleveling plus mesh-bed compensation September 06, 2018 11:28PM |
shadowphile
Right now I'm trying out using a thin plate of polycarbonate as a printing surface. It's pretty flat but I don't have a spec. But it seems to grip a metal straight-edge pretty well along the entire length.
How do I do 'laser-squaring'? Some kind of commercial? How does having multiple layers of adjustable feet work help? Isn't one layer enough?
Also, I've always had the impression that anything that can change the length of the belt-path (like deflection) during operation would cause position errors proportional to the amount of deflection.
Re: autoleveling plus mesh-bed compensation September 07, 2018 03:55AM |
Re: autoleveling plus mesh-bed compensation September 07, 2018 09:27AM |
Re: autoleveling plus mesh-bed compensation September 07, 2018 11:54AM |
Re: autoleveling plus mesh-bed compensation September 07, 2018 01:41PM |
Re: autoleveling plus mesh-bed compensation September 09, 2018 09:55PM |
Re: autoleveling plus mesh-bed compensation December 02, 2018 03:14AM |
Re: autoleveling plus mesh-bed compensation December 02, 2018 07:22PM |
shadowphile
How does G30 auto-leveling compare to mesh-bed leveling? At first glance it seems like both of them just put the printing plane as a best fit of the deviations.
What does G30 fix that G29 does not, or vice-versa? When is using one or the other (or both) most appropriate (or not)? I'm interested in precision.
Re: autoleveling plus mesh-bed compensation December 02, 2018 10:04PM |
Re: autoleveling plus mesh-bed compensation December 03, 2018 09:34PM |
Re: autoleveling plus mesh-bed compensation December 04, 2018 12:06AM |
shadowphile
One impression I got that neither of you pointed out (assuming I'm right) is that G30 does a best fit of a plane, and G29 actually adjusts the z-height as needed across the bed, essentially adding a warp to match the uneven surface, but that non-flat adjustment continues all the way up, hence the taper-off function.
In this context it seems like G30 would adjust (almost) orthogonal fit then G29 used to cope with the residual peaks.
shadowphile
I'm not sure how much more I can do with manual calibration. I have a thick tooling plate that gave me .01mm errors but after inverting the machine to do some work I can't get it lower than about .02 now. An additional metal plate with a sheet of PC glued on raises that to .05. I'm experimenting with solid PC as a print surface but trying to keep it super flat, especially when heated, is hard .
shadowphile
I finally built a piezo detector that uses the nozzle and immediately saw much better results, even after painfullyy going through all the H value measurements. Halleluja!
Re: autoleveling plus mesh-bed compensation December 10, 2018 10:09PM |
Re: autoleveling plus mesh-bed compensation December 10, 2018 10:48PM |
Re: autoleveling plus mesh-bed compensation December 11, 2018 02:40AM |
I have not attempted any prints that might have been affected by G29s, I only used it to report a heightmap out of curiosity when I found out how easy it was from webcontrol. Who doesn't like 3d surface plots!Quote
Also are you adding the G29 S1 G-code command to your start code on your slicer to load up the mesh compensation before the print starts?
The few times I ran G29 was after G30. Except once I tried directly after bootup. That left a heightmap with a ~2mm offset that I figured is zero'd out with the G30. (my config file likely needs updating)Quote
Are you ensuring G30 is not used after the mesh bed has been done?
I run 6 outer points, 3 inner points, and the center. I had the impression that too many points was counter-productive... Since G30 assumes a flat bed, then it must be placing some kind of tiled plane. I didnt think more interstitial probe spots would add much to the plane's placement. Maybe I'm wrong.Quote
Are you running G30 a few times with more than 7 probe points (suggest at least 16) , then running G30 with 20mm probe points?
My rod lengths are set in the config file; everything else is derived from G30s. Last time I checked my dimensions and ortho-ness ( because 'perpendicularity' is just a bloated word that should be struck from the dictionary!) were spot on, or at least as well as I could measure with my calipers on a single-layer 150mm square print pattern.Quote
Have you got your delta radius set right?
Re: autoleveling plus mesh-bed compensation December 11, 2018 03:13AM |
shadowphile
I still don't understand why I can't use the mesh-bed topology measurements (G29) to do tiny (ie .02mm) adjustments to a well-built system, not major corrections to a badly built system. Is it not an accurate process?
thanks
Re: autoleveling plus mesh-bed compensation December 11, 2018 04:00AM |
I doubt that. It is probably only a weighted average: continuous but not smooth. Trying to make it smooth would be a waste of cycles. But maybe duet has enough cycles to wasteQuote
shadowphile
I was picturing the height correction being based on a smooth surface forced-fit to the grid points, smoothed to at least the first derivative. 2nd would be better.
Re: autoleveling plus mesh-bed compensation December 11, 2018 04:01AM |
Re: autoleveling plus mesh-bed compensation December 11, 2018 04:08PM |
