Reducing vibrations before "extruder" reaches defined position September 21, 2018 07:50AM |
Re: Reducing vibrations before "extruder" reaches defined position September 21, 2018 08:03AM |
Arnix
Hi to all.
Im wondering if it's possible to reduce movement speed few cm before endpoint.
e.g. if the object is, lets say 50 cm from base center and if the moving speed is
fast, would it be possible to reduce this speed few cm before endpoint. ?
I just want to reduce vibrations that are produced if the extruder stops without "slow breaking"...
A.
Re: Reducing vibrations before "extruder" reaches defined position September 21, 2018 12:22PM |
Re: Reducing vibrations before "extruder" reaches defined position September 21, 2018 04:32PM |
Re: Reducing vibrations before "extruder" reaches defined position September 22, 2018 02:43AM |
It makes perfect sense for a pick and place machine.Quote
No clue why you want it and I do not consider it a good feature anyway.
Re: Reducing vibrations before "extruder" reaches defined position September 23, 2018 07:47AM |
Re: Reducing vibrations before "extruder" reaches defined position September 23, 2018 11:27AM |
Re: Reducing vibrations before "extruder" reaches defined position September 23, 2018 02:12PM |
Re: Reducing vibrations before "extruder" reaches defined position September 23, 2018 04:50PM |
Re: Reducing vibrations before "extruder" reaches defined position September 24, 2018 04:34AM |
Re: Reducing vibrations before "extruder" reaches defined position September 24, 2018 05:17AM |
Re: Reducing vibrations before "extruder" reaches defined position September 24, 2018 07:07AM |
Re: Reducing vibrations before "extruder" reaches defined position September 24, 2018 10:01AM |
Re: Reducing vibrations before "extruder" reaches defined position September 24, 2018 10:49AM |
If the location below is mechanically reachable (*) then it looks like firmware bug.Quote
Arnix
E.g. i can locate object and place the "extruder" right on top of it but when i lower the head down, arms are moved aside and it's quite hard to lower the arm down, on that specific location.
Re: Reducing vibrations before "extruder" reaches defined position September 25, 2018 04:52PM |
