Hi O_lampe !
I have set 10 pcb's for production and they will be ready in few days.
After i solder them, i can send the results.
So, according to specs, this can be used in RRF.
How can i wire this to DUET3D ?
As you know, am using nema23 / 1.8 degrees / 3A motors with inbuilt 10:1 gearbox.
From mechanical point, i can easily connect them to each motor shaft but how should
i do the wiring to DUET ?
A.
Edited 1 time(s). Last edit at 09/27/2018 02:57AM by Arnix.
