Re: Kossel Delta xxl build project HELP May 09, 2019 11:07AM |
Re: Kossel Delta xxl build project HELP May 09, 2019 03:45PM |
Re: Kossel Delta xxl build project HELP May 09, 2019 04:15PM |
Re: Kossel Delta xxl build project HELP May 09, 2019 04:56PM |
Re: Kossel Delta xxl build project HELP May 09, 2019 04:57PM |
Re: Kossel Delta xxl build project HELP May 09, 2019 05:09PM |
Re: Kossel Delta xxl build project HELP May 09, 2019 05:22PM |
Re: Kossel Delta xxl build project HELP May 09, 2019 05:28PM |
Re: Kossel Delta xxl build project HELP May 09, 2019 05:30PM |
Re: Kossel Delta xxl build project HELP May 09, 2019 05:33PM |
Re: Kossel Delta xxl build project HELP May 09, 2019 06:03PM |
Re: Kossel Delta xxl build project HELP May 09, 2019 06:47PM |
Re: Kossel Delta xxl build project HELP May 09, 2019 07:18PM |
Re: Kossel Delta xxl build project HELP May 10, 2019 02:55AM |
alex773
Can you please help me to set it up for 6 factors with at least 18 probe points. I'm so happy. Is moving.
Re: Kossel Delta xxl build project HELP May 10, 2019 10:01AM |
alex773
Thank you so much. I did change per your instructions and it is working. Can you please help me to set it up for 6 factors with at least 18 probe points. I'm so happy. Is moving.
Re: Kossel Delta xxl build project HELP May 10, 2019 12:04PM |
Re: Kossel Delta xxl build project HELP May 10, 2019 12:08PM |
Re: Kossel Delta xxl build project HELP May 10, 2019 12:09PM |
Re: Kossel Delta xxl build project HELP May 10, 2019 02:18PM |
Re: Kossel Delta xxl build project HELP May 10, 2019 06:15PM |
Re: Kossel Delta xxl build project HELP May 10, 2019 06:27PM |
Re: Kossel Delta xxl build project HELP May 10, 2019 06:36PM |
Re: Kossel Delta xxl build project HELP May 10, 2019 06:41PM |
Re: Kossel Delta xxl build project HELP May 11, 2019 02:19PM |
Re: Kossel Delta xxl build project HELP May 12, 2019 02:08AM |
alex773
Something I not going right.
When I turn the printer on the hotend temperature it is 38 degree C , but the hotend is off and cold . I checked the connection and everything looks good. Where is the problem?
Re: Kossel Delta xxl build project HELP May 12, 2019 04:14AM |
Re: Kossel Delta xxl build project HELP May 12, 2019 01:36PM |
Re: Kossel Delta xxl build project HELP May 12, 2019 03:01PM |
Re: Kossel Delta xxl build project HELP May 12, 2019 03:34PM |
alex773
Thank you David for your input.
If you remember in first place when I first started the printer the difference between the bed and hotend it was almost 4 degrees C.
There is no option to fix this problem ?
Thank you
Re: Kossel Delta xxl build project HELP May 12, 2019 03:46PM |
