Kossel Delta xxl build project HELP
Posted by alex773
Re: Kossel Delta xxl build project HELP
June 05, 2019 04:50PM
Is this all probe points or just some that it fails on? Does it go through the motions of probing?
My 3D Printing YouTube Channel
Better Living Through 3D Printing
Follow me on Instagram and Twitter
Instagram
Twitter
June 05, 2019 04:56PM
When calibrating for the first time you should increase the dive height (M558 H parameter) temporarily to make sure that the probe can reach the bed. This is covered at [duet3d.dozuki.com].
It's normal for the trigger light to illuminate sometimes while printing, because of the high sensitivity of the nozzle contact probe, and it doesn't cause any problems.
June 05, 2019 07:58PM
Thank you FA-MAS. It does go through the all motion of probing and only few of them fail to touch the bed.
Edited 1 time(s). Last edit at 06/05/2019 08:00PM by alex773.
June 05, 2019 08:09PM
Thank you David.This is what I have on Z-probe:
; Z-Probe
M558 P5 R0.4 H5 F1200 T6000 ; Set Z probe type to effector and the dive height + speeds
G31 P100 X0 Y0 Z-0.1 ; Set Z probe trigger value, offset and trigger height
M557 R149 S20 ; Define mesh grid
What value of H parameter I should have in order to have the G32 command probe all points ?
Edited 1 time(s). Last edit at 06/05/2019 08:16PM by alex773.
June 05, 2019 09:20PM
Increase the H parameter in your M558
Instagram
Twitter
June 05, 2019 09:32PM
Thank you FA-MAS. Right now the H parameter is H5. Should I make it H30 or how much ?
June 05, 2019 09:35PM
Estimate it, watch the points where it doesn’t trigger and gauge it. If it looks like you only need 2 mm, add 2. More or less it’s up to what you see.
Instagram
Twitter
June 05, 2019 09:37PM
I will do that. I'm starting the printer right now. Let's hope it works.Thank you
June 05, 2019 10:25PM
Something is not right. I changed H parameter from H5 to 7 ,9 , 12 , 14 , 16 and I still have 6 to 13 points not probing the bed.
Now the G30 is not touching the bed , is just going up 16mm
Edited 1 time(s). Last edit at 06/05/2019 10:28PM by alex773.
June 05, 2019 10:28PM
I wonder if it’s the wiring. Maybe it’s losing connection at certain spots? I would think of your machine is built as accurate as it is, you shouldn’t see very much deviation between the points. It’s gotta be something else. My bet is wiring.
Instagram
Twitter
June 05, 2019 10:36PM
I don't know where to look for this issue. I was so excited about this printer and now is not working
June 05, 2019 10:54PM
I’d start with replacing the probe wiring between the effector and Duet.
Instagram
Twitter
June 05, 2019 11:45PM
When I start the printer for the first time G 30 and G 32 are faine. I was able to calibrate with the bed.g you sent me. I don't know what is going on. Thank you for your help
June 06, 2019 09:47AM
I checked the wiring between effector and the board and everything looks good.
June 06, 2019 09:55AM
I'm not sure what else to chase, maybe dc42 has some suggestions.
Only other thing I can think of is to choose one of the points where probing fails and try to probe it individually and watch it to see how it acts.
Instagram
Twitter
June 06, 2019 05:34PM
Are you getting any error messages? Is the green light on the effector flashing before the nozzle touches the bed? Can you link to a video of it?
June 06, 2019 10:25PM
It was one time solid green when the printer it was homend. I will upload a video but it is going to take a while, I never did this before. Thank you David
June 06, 2019 10:29PM
I do have a big issue with the Fan Duct for my Smart Effector. I tried this fun ducts but none of them are fitting in the right position. The fan Is blowing on the heater block.I do have the E3D V6 Hotend
open | download - IMG_20190606_205748.jpg (398.6 KB)
open | download - IMG_20190606_203842.jpg (291.7 KB)
June 07, 2019 07:34AM
That’s exactly why I made my own version. I modeled everything in CAD and saw that before I built. I saw that exact issue. I’ll link you to my fan duct when I get to a computer.
Instagram
Twitter
June 07, 2019 09:38AM
Here's the link to the document,
https://cad.onshape.com/documents/cdaad6da8b99bae2a9d9dd0e/w/2dbd663c0fc4ada4dfde92d3/e/8729b3767facd04581cd7c02
You'll want both the effector-fan-bracket and the 40-mm-fan-duct.
A note about the fan duct, I dislike assembling using captive hex nuts or having to use a wrench. So it's designed to be used with heat set inserts. Specifically these.
https://www.amazon.com/Uxcell-a16041800ux0833-Knurled-Threaded-Embedded/dp/B01IYWUUH8/ref=sr_1_2?keywords=uxcell+m3+heatset&qid=1559914581&s=gateway&sr=8-2
Both have their own tabs at the bottom. Once you're on one of them, on the left side under parts, right click the part and then choose export.
Export it as stl and leave the settings as they are, and make sure the options box at the bottom says download.
It should download the stl for you to use.
Here's a screenshot of how my duct clears.
Edited 2 time(s). Last edit at 06/07/2019 09:41AM by blt3dp.
Instagram
Twitter
June 07, 2019 10:35AM
Thank you. I'm going to print them and post some pictures. Thank you
Edited 2 time(s). Last edit at 06/07/2019 01:10PM by alex773.
June 07, 2019 01:10PM
On the parts you have only 40mm fan duct and fan output. No effector-fan-bracket. Can you please share the link for it ? Thank you
Nevermind I finally found the bracket
Edited 1 time(s). Last edit at 06/07/2019 02:08PM by alex773.
June 10, 2019 04:26PM
Just thought I'd see if you've made any progress.
Instagram
Twitter
June 10, 2019 06:01PM
[www.youtube.com]
Thank you FA-MAS. I got the prints in this morning, and I'm going to install them tonight. I uploaded a video about auto-calibration.
Edited 1 time(s). Last edit at 06/10/2019 06:03PM by alex773.
June 11, 2019 08:13AM
On your calibration video it looks like it always triggers prematurely at one or two point at the left hand edge of the bed. Does the green LED flash when it does that? If yes, then you have set the Smart Effector trigger sensitivity too high. If no then you probably have a bad crimp connection in the output pin of the wire that connects to the 8-way connector.
Edited 1 time(s). Last edit at 06/11/2019 08:14AM by dc42.
June 11, 2019 10:32AM
dc42
I noticed that too, and it seems from the web interface that it doesn't report an issue at any of the points (eg. probe not triggered message). So it must think it successfully triggered.
Edit: Looking back at your config.g, it looks like you're using default settings for the probe. I'm using the same settings and it's ok. I'm still betting on a bad crimp/cable.
Edited 1 time(s). Last edit at 06/11/2019 10:57AM by blt3dp.
Instagram
Twitter
June 11, 2019 01:57PM
I'm going to check out the 8-way connector. I just have to figure out how to take the cables out from the connector.
June 11, 2019 02:49PM
alex773
Exacto knife or a small flat head screwdriver to push down the little tabs in the pins as you pull them out of the connector.
Instagram
Twitter
June 11, 2019 03:04PM
Thank you. I don't have a Exacto knife but I do have a very small flat head screwdriver.
June 11, 2019 04:28PM
alex773
The tips of a pair of fine-point tweezers work too.
