Kossel Delta xxl build project HELP
Posted by alex773
Re: Kossel Delta xxl build project HELP
June 11, 2019 05:20PM
I will try the fine-point tweezers too , as long I don't have to redo the whole 8-way connector. Thank you
June 11, 2019 11:42PM
I finally got the Fan Duct installed. Please take a look at the attached pictures and tell me what do you think. I do have a question. The fan-output should go through the fan-duct , the rectangular hole , or it's just for orientation ? Mine is not going through. Thank you
open | download - IMG_20190611_222652.jpg (243.4 KB)
open | download - IMG_20190611_222635.jpg (287.7 KB)
June 11, 2019 11:58PM
That looks right. How I have mine setup. It's a clear path from the fan through the duct right? Like no left over support material or anything? Mine seem to be working fine and I'm using a Noctua 40x10mm 12v fan. Wonder if the one you're using doesn't have enough power to overcome the static pressure caused by putting it on a duct.
My 3D Printing YouTube Channel
Better Living Through 3D Printing
Follow me on Instagram and Twitter
Instagram
Twitter
June 12, 2019 12:12AM
This is the fan what I have. This setup is way better than what I have before. Thank you.
open | download - IMG_20190611_230532.jpg (315.3 KB)
June 12, 2019 09:51AM
Is this normal ?
[youtu.be]
June 12, 2019 04:42PM
Mine does that too. Though there's stuff in the way preventing very much rotation.
Instagram
Twitter
June 12, 2019 04:57PM
Thank you for clarifying this to me.
June 12, 2019 06:04PM
I notice in that video that 2 of the nuts holding the ball studs are missing, although I guess that is just because you temporarily removed the print cooling fan.
June 12, 2019 06:44PM
You are right,David. I was worried about the heatsink fan. I'm going to put all together tonight and fix the 8-way connector. Thank you
Edited 1 time(s). Last edit at 06/13/2019 12:17AM by alex773.
June 13, 2019 12:35AM
I finally got time to check the 8-way connector. It was not that hard to take the plugs out from the connector ( based on your recommendation ) , and Yes it was a bad crimp connection in the output pin. Now the G30 and G32 commands work with no problem. Thank you so much.
June 14, 2019 10:56AM
dc42
In that case it sounds like either one of the LEDs or the series resistor has blown. Did you run the effector at 24V with the "on for 12V" jumper installed? If you did then the 604 ohm series resistor has probably blown. If not, then most likely one of the 3 LEDs has failed - which is unlikely but not impossible. The one with 12V or 24V across it is the one that has failed.
I run the Effector at 24v with no jumper installed. I have D1, D7, and D9 next to the LEDs . Which is the one I have to replace in order to fix my lights ? Can you please tell me what LED is suitable ? Thank you
June 14, 2019 11:11AM
I would check those resistors with a multimeter anyway, and of course make sure there's no jumper as you're using pure 24v
Looking at the schematic, if it were not the resistor and none of the leds come on, I would start with the first in the series. It goes D1 --> D9 --> D7
I found the part # on the Duet forums, CLM3C-WKW-CWBYA153
Edited 1 time(s). Last edit at 06/14/2019 11:13AM by blt3dp.
Instagram
Twitter
June 14, 2019 03:05PM
Thank you FA-MAS. I have to order the LED. I was thinking to replace them with something like this : [www.amazon.com]
The original ones are small and I don't think It's very easy to solder .
Edited 2 time(s). Last edit at 06/14/2019 03:27PM by alex773.
July 08, 2019 11:04AM
Just checking to see how you've gotten on. Also, thought it might be of interest. Though probably less for you, my mounting method is different and I found that the fan duct was going to hit them. I changed to this, and it fits perfectly with lots of clearance between it and the hotend heatsink as well as the bottom of it is aligned with the bottom of the heater block giving lots of clearance for bed attachments.
https://www.thingiverse.com/thing:2808152
But, when I imported it into CAD, even though it was manifold, I could see that the mesh wasn't very good. Multiple weird intersections and odd geometry was causing my slicer to do stuff unnecessarily complicated. I ended up redrawing the entire thing.
https://cad.onshape.com/documents/cdaad6da8b99bae2a9d9dd0e/w/2dbd663c0fc4ada4dfde92d3/e/04bf04ebf723a61574b2c073
Instagram
Twitter
July 18, 2019 09:40AM
I do apologise for delay. As you know I have this fan duct from thingiverse installed with no success on my machine. I have no clearance. It was to close to the build surface. I don't know if it was the bracket or the fan duct. I really like this fan duct but It was not working for me. Thank you so much for sharing this with me. I'm going to print your file today and I hope It will fit better. Can you please post a picture to show how Is fitting on your set up ?
Thank you
I finally figured out how to fix the lights
July 18, 2019 01:24PM
I'm not currently near the printer, but I will say that I originally tried using the bracket that dc42 created and when I attached this fan shroud, it dipped below the nozzle. I had to use the one from the actual thingiverse page.
If you look at my effector_assembly tab, it sits exactly like that, parallel to the bed, actually slightly above the bottom of the heater block and has quite a bit of space between it and the hotend fan shroud.
Instagram
Twitter
July 18, 2019 05:27PM
I was trying to load the file to Simplify 3D and this is what I got. I can't place the fan duct on the build surface. The bracket is ok. Do you know by any chance why ? I tried everything on S3d and It is not working.
Thank you
Edited 1 time(s). Last edit at 07/18/2019 05:40PM by alex773.
open | download - Screenshot (24).png (225 KB)
open | download - Screenshot (25).png (162 KB)
July 18, 2019 08:27PM
Hrmm, it dropped down just fine when I brought it into Prusa Slicer 2.0
Maybe there's an option in Simplify3d that would move it down? Maybe https://www.youtube.com/watch?v=XJi4_ScDLtE
Instagram
Twitter
July 18, 2019 09:53PM
I tried the Place surface on bed and its not working. I will try again. Thank you
July 18, 2019 10:39PM
This is the only way to Place surface on bed.
I will try to print it and let you know. Thank you
Edited 1 time(s). Last edit at 07/18/2019 10:44PM by alex773.
open | download - Screenshot (26).png (191.2 KB)
July 19, 2019 06:38PM
I have them ready for mounting. Tonight.
Thank you
open | download - IMG_20190719_172642.jpg (228.8 KB)
July 22, 2019 07:49AM
I installed the Fan Duct. This is how It looks on Smart effector. Thank you
open | download - IMG_20190721_224944.jpg (284 KB)
open | download - IMG_20190721_224845.jpg (284.4 KB)
July 22, 2019 07:56AM
I actually had a few questions for you. How was installing the nimble? Did the adapter from Shapeways fit well or did it require some rework? What length cable did you get? Where did you mount the motor? And how are you managing the wires coming from the effector? Also does it work well? If you could attach a couple of pics, I’d appreciate it.
Instagram
Twitter
July 22, 2019 08:31AM
Installation of Nimble was easy and straight forward. The adapter from Shapeways It is working very good.
The only thing I have to do to make it work It was the hole for the Bowden tube It was to tight. The drive cable length is 95 cm. The motor Is mounted on Z tower. I'm not at the printer right now but I will post some pictures for the cables and measurements where I have the motor . The Nimble Is working very well but I can't compare ( I don't have another printer ). I'm struggling with the S3D settings. I do love the Nimble.
July 22, 2019 12:07PM
I noticed there was a lip inside the hole in the adapter where the ptfe is supposed to go, it prevents me from pushing it all the way through. From what I understand, the ptfe is supposed to be flush with the top of the adapter and go all the way into the heatsink of the hotend. Did you have to file out that hole a little to get the ptfe to fit?
Instagram
Twitter
July 22, 2019 02:14PM
For the hole I use a drill bit close to the exterior diameter of ptfe. I'm going to post some pictures when I get back home. Let me know if you need more pictures
Edited 1 time(s). Last edit at 07/22/2019 03:39PM by alex773.
open | download - IMG_20190722_133357.jpg (301.6 KB)
open | download - IMG_20190722_133307.jpg (284.7 KB)
open | download - IMG_20190722_133253.jpg (279.4 KB)
July 29, 2019 11:33AM
There is no lip on the adapter. The Nimble seats on top of the ptfe.
August 01, 2019 10:32AM
Are you finding that rigidly mounting the nimble motor/motor bracket is sufficient or do you think one of the swivel mounts to allow the motor to move a little as the effector moves is needed?
Instagram
Twitter
August 02, 2019 08:20AM
Mine is working fine just with the bracket. I have in my PC at home a 3D file with a Gimbal mount for 2020 Delta frame, but I never used it. I can post the file Monday when I will be back in town. Did you mount the Nimble on the adapter ?
Edited 1 time(s). Last edit at 08/02/2019 09:01AM by alex773.
August 02, 2019 12:42PM
Just curious, mine is due to arrive today and was just thinking that I could go straight to the gimbal mount if it was necessary. Good to know it isn't, I'll just mount it.
Instagram
Twitter
