Kossel Delta xxl build project HELP
Posted by alex773
Re: Kossel Delta xxl build project HELP
August 02, 2019 09:36PM
Could you take a pic of the effector from beneath? I got my nimble installed I’m finding that one the washer/nuts protruding from the bottom interfere with the heat sink fan installation.
My 3D Printing YouTube Channel
Better Living Through 3D Printing
Follow me on Instagram and Twitter
Instagram
Twitter
August 03, 2019 08:15AM
I'm not going to be in town until Monday. If Is not to late I will post some pictures when I get home. If I remember correctly I have the heat sink fan mounted up side down for the same reason. I have to double check.
Edited 1 time(s). Last edit at 08/03/2019 08:39AM by alex773.
August 05, 2019 11:18PM
This is the way I installed my heat sink Fan. I did file a lock nut to have room for the heat sink fan. Please let me know if you need any pictures from a specific angle
Edited 1 time(s). Last edit at 08/05/2019 11:23PM by alex773.
open | download - IMG_20190805_221256.jpg (353.7 KB)
open | download - IMG_20190805_221246.jpg (363.6 KB)
open | download - IMG_20190805_221158.jpg (273.1 KB)
open | download - IMG_20190805_221122.jpg (284.7 KB)
open | download - IMG_20190805_221109.jpg (280.5 KB)
open | download - IMG_20190805_221034.jpg (294.3 KB)
open | download - IMG_20190805_221013.jpg (260.2 KB)
August 06, 2019 11:05AM
Yeah, mine's pretty much the same way but flipped because mine's a v2 effector. I ended up modeling a fan duct for the hotend that completely cuts off one corner and it clears fine. I think I'm going to switch to m2.5 button head screws and fiber washers from the bottom and that should clear better.
Instagram
Twitter
September 13, 2019 04:39PM
Hi Blt3dp. Just checking to see how you've gotten the Nimble installed. Are you happy with it ?
September 13, 2019 10:43PM
I ended up getting some m2.5 button head screws, some fiber washers and half height nuts. I installed them from the underside and used locktite to install the nimble adapter. I can now use the official e3d fan shroud. I have almost 2 mm of clearance. And the nimble itself is awesome, I think it’s a great piece of hardware.
Instagram
Twitter
November 20, 2019 04:28PM
After so much time I finally was able to print with success some models . ( See the attachments). Until In this morning when I try to calibrate the printer and I noticed that the printer Is start skipping some calibration points.I also noticed that when I home the towers the hotend Is moving to the left after homming.
I'm doing something wrong ?
open | download - 15742852281349109120066524516802.jpg (347.9 KB)
open | download - 15742852626592037580732183110649.jpg (343.2 KB)
November 20, 2019 04:43PM
I noticed something similar with mine. You might check to make sure your hotend isn't coming loose from the effector. I noticed my hotend wobbling during a print. Turns out the nut holding it tight to the effector had worked it's way loose. I paused the print and tightened it up and was able to finish the print. Then I went back and put thread locker on it. I haven't had the problem since.
Instagram
Twitter
November 20, 2019 05:32PM
Thank you blt3dp for your help. I checked the hotend and isn't loose. Everything looks fine
November 21, 2019 10:08AM
There haven't been any changes to the machine have there?
I'd check all the usual stuff like the condition of the belts, I at one point had a belt fail where a section of it was stretched and the teeth were super far apart, probably too high tension. Check their tension too. Check to make sure that the pulleys are still tight on your motors, they've been known to come loose and semi rotate around the shaft.
I suppose it could be adjusting the position due to the calibration, I would watch it when it calibrates. If it skips some points, watch it to see if it triggers either too early or not all. Maybe that will give you a clue on what's going on.
Instagram
Twitter
November 21, 2019 06:21PM
Thank you for your help. I checked what you said and everything looks good. I tried to calibrate with the hotend and bed off and it worked. Where do you think it is the problem ? Thank you
November 22, 2019 11:31AM
I'd probably check the cabling to the effector again.
Instagram
Twitter
November 22, 2019 06:57PM
Thank you. I will check out the cables and I let you know.
January 19, 2020 09:42PM
Hey alex773, I was wondering what kind of surface quality you’re getting with the nimble. It’s looking to me like the cable on the nimble is slightly flexing my Effector and the layers don’t stack up exactly like I’d like.
Instagram
Twitter
January 23, 2020 09:53AM
"Until In this morning when I try to calibrate the printer and I noticed that the printer Is start skipping some calibration points.I also noticed that when I home the towers the hotend Is moving to the left after homming."
Try turning off fans during calibration - worked for me before I twisted my cables smiling smiley
Edited 1 time(s). Last edit at 01/23/2020 09:54AM by leif.
February 11, 2020 11:25AM
Hi blt3dp. Sorry for delay but for the last 6 months I was in and out from town and I didn't have time for the printer. To be honest with you I'm not 100 % satisfied with the surface finish and I have some failed prints. Send me an Stl to print and I will post the pictures
Edited 3 time(s). Last edit at 02/11/2020 02:03PM by alex773.
February 11, 2020 11:43AM
leif
Hi Leif. Thank you for your response. I have my cables twisted and I checked the connections for the cables. The only way to calibrate my printer is to have the hotend off and the bed off. After calibration I turn on the hotend and the bed .
February 14, 2020 10:50AM
Hi Leif, can you please tell me how I turn the fans off during calibration. I want to try your way, maybe it will work for me too. Thank you
February 14, 2020 12:25PM
I would think that you would do it in your bed.g
After the M561 I would do something to turn off thermostatic mode on my hotend fan (I'd copy the line from my config.g but set it to H-1)
Something like
M106 P1 H-1
Then at the end, put it back to the way it was but just copying the exact M106 command from your config.g
Instagram
Twitter
February 14, 2020 02:49PM
Thank you blt3dp. I'm going to try this. Send me a Stl to print and I will post pictures to see the difference
February 17, 2020 08:36PM
Hello to everyone.
It's been a year now since I started working ( building) on my printer. It was a long and great journey. This project was not possible without your help and support. The printer is fantastic ( from my shoes ). I still have to do some adjustments and tweaking, to get the perfect print but sooner or later I will get there. I know for most of the people is just another printer but for me Is THE PRINTER. Thank you David for your help and support , for design and BOM. Thank you blt3dp for being next to me and helping me out all this time
March 07, 2020 10:11AM
Hi, Blt3dp. Did you try to mount the Nimble motor on a gimbal mount to see if any difference ?
March 07, 2020 10:51AM
I took it off, I believe it was flexing the smart effector slightly and causing layer registration issues. I switched to a bowden hemera and have been getting really clean prints.
Instagram
Twitter
March 07, 2020 04:42PM
I will post some pictures with my prints for you.
Can you please post some pictures with your Hemera set up.
Edited 2 time(s). Last edit at 03/07/2020 09:42PM by alex773.
open | download - IMG_20200308_205818.jpg (340.2 KB)
open | download - IMG_20200308_205942.jpg (298.6 KB)
March 09, 2020 11:18AM
The scar on the top of the cube where the nozzle dug in points to some over extrusion, also probably the blobs where your perimeters start on the 2nd print. Make sure you don't have any extrusion multiplies or flow rate multipliers set. I would go through calibrating the e-steps, Triffid Hunter's Calibration Guide
I also noticed that my layers weren't lining up very well. That's when I found the numble flexing the Smart Effector. I'll get some pictures of my Hemera setup.
Instagram
Twitter
March 09, 2020 02:43PM
Thank you blt3dp. I will check the extrusion multiplies . This pictures are your cube Stl. Please take a look on the corners, all are the same. No matter what I was trying out the corners are like this.
open | download - IMG_20200309_201839.jpg (284.7 KB)
open | download - IMG_20200309_201927.jpg (289.8 KB)
open | download - IMG_20200309_202011.jpg (266.6 KB)
March 09, 2020 02:45PM
Would you post your current config.g.
Instagram
Twitter
March 09, 2020 04:26PM
; Configuration file for Duet WiFi (firmware version 1.21)
; executed by the firmware on start-up
; generated by RepRapFirmware Configuration Tool v2 on Sat Mar 30 2019 20:58:40 GMT-0500 (Central Daylight Time)
; General preferences
G90 ; Send absolute coordinates...
M83 ; ...but relative extruder moves
M665 R179 L360 B150 H470 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
; Network
M550 P"abc Printer" ; Set machine name
M552 S1 ; Enable network
;*** Access point is configured manually via M587
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet
; Drives
M569 P0 S0 ; Drive 0 goes backwards
M569 P1 S0 ; Drive 1 goes backwards
M569 P2 S0 ; Drive 2 goes backwards
M569 P3 S0 ; Drive 3 goes backwards
M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation
M92 X200.00 Y200.00 Z200.00 E2600 ; Set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E36.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; Set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E120.00 ; Set accelerations (mm/s^2)
M906 X1000.00 Y1000.00 Z1000.00 E500.00 I35 ; Set motor currents (mA) and motor idle factor in per cent
M84 S10 ; Set idle timeout
; Axis Limits
M208 Z0 S1 ; Set minimum Z
; Endstops
M574 X2 Y2 Z2 S1 ; Set active high endstops
; Z-Probe
M558 P5 R0.4 H5 F1200 T6000 ; Set Z probe type to effector and the dive height + speeds
G31 P100 X0 Y0 Z-0.1 ; Set Z probe trigger value, offset and trigger height
M557 R149 S20 ; Define mesh grid
; Heaters
M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
M307 H0 A278.0 C1612.7 D19.6 V24.2 B0
M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
M143 H0 S120 ; Set temperature limit for heater 0 to 120C
M307 H1 A635.2 C343.6 D4.4 V24.2 B0
M305 P1 X200 ; Configure PT100 for heater 1
M143 H1 S320 ; Set temperature limit for heater 1 to 320C
; Fans
M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
; Tools
M563 P0 D0 H1 F0 ; Define tool 0
G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C
; Automatic saving after power loss is not enabled
; Custom settings are not configured
Thank you
March 09, 2020 07:46PM
I would change your e-steps to 2700, it's what Zesty says is a starting point. I got great prints without having to change them.
Jerk should be 40
Max speed for E is pretty low @ 20 mm/sec
See the changes below
M92 X200.00 Y200.00 Z200.00 E2700 ; Set steps per mm
M566 X600.00 Y600.00 Z600.00 E40.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E7200.00 ; Set maximum speeds (mm/min)
Also make sure your slicer doesn't have any jerk or acceleration value settings that are lower than your config.g
Instagram
Twitter
March 09, 2020 10:19PM
Thank you blt3dp. I made the changes per your instructions :
Old :
New :
Old:
New :
Old :
New :
Thank you
Edited 1 time(s). Last edit at 03/09/2020 10:23PM by alex773.
