Re: Kossel Delta xxl build project HELP
April 01, 2020 07:16PM
Try this gcode. Sliced with Prusa Slicer, I set the seam to rear so theres a common start and end point. Hopefully that would tell us if it's just the start/stop points.
My 3D Printing YouTube Channel
Better Living Through 3D Printing
Follow me on Instagram and Twitter
Instagram
Twitter
open | download - blt3dp_3DBenchy.gcode.zip (510.4 KB)
April 02, 2020 02:08AM
This is the print from your Gcode. I will post more pictures in the morning. Thank you
open | download - IMG_20200402_010520.jpg (184.2 KB)
open | download - IMG_20200402_010453.jpg (192.7 KB)
open | download - IMG_20200402_010421.jpg (223.6 KB)
April 02, 2020 01:54PM
This is the same gcode, different color. That mess on the left side of the Benchy is from the cooling fan ? I noticed that you changed the speed of the cooling fan during the print.
open | download - IMG_20200402_123258.jpg (229.8 KB)
open | download - IMG_20200402_123021.jpg (185.6 KB)
open | download - IMG_20200402_122915.jpg (204.9 KB)
open | download - IMG_20200402_122856.jpg (234.6 KB)
open | download - IMG_20200402_122711.jpg (170.3 KB)
open | download - IMG_20200402_122634.jpg (161.9 KB)
April 02, 2020 02:00PM
Yeah, the bow of the boat is hard to print. It requires fairly good cooling from what i've read. I've never printed a benchy myself. I'm betting the fan shrouds we use aren't really optimal, I plan on upgrading mine.
Prusa Slicer does control the fan speed if you tell it to as well as it will slow down so layers don't go down too quick. So you're not stacking hot plastic on hot plastic and it turns into a gummy mess.
Instagram
Twitter
April 02, 2020 02:31PM
I was looking for a better solution to replace the cooling fan but I couldn't find one. What do you think about your gcode on my machine ? Besides the cooling fan, do you think is something wrong with the printer or the slicer ?
April 02, 2020 02:54PM
I think your machine is fine, I think most of what you're seeing is a Slicer problem. Looks like Simplify is drawing the outer perimeters too thick. After figuring that out, you'll want to tune the retraction and do something with the cooling.
I was thinking of going with this duct or something similar. That could use a blower fan instead of an axial fan.
https://forum.duet3d.com/topic/10227/part-cooling-duct-for-a-5015-fan
Edited 1 time(s). Last edit at 04/02/2020 02:58PM by blt3dp.
Instagram
Twitter
April 02, 2020 03:14PM
Are you planning to use a 5015 fan ?
Like this one ?
[www.amazon.com]
Edited 2 time(s). Last edit at 04/02/2020 10:38PM by alex773.
April 02, 2020 04:00PM
Yes, most likely a 5051 fan.
Instagram
Twitter
April 02, 2020 11:02PM
Are you planning to use a 2x 5015 fan set up or just one 5015 fan . They are not to many models out there for smart effector .
April 03, 2020 11:07AM
I was thinking about 2 5051 with some sort of ring cooler to push air out all the way around the nozzle. I like the mounting method of the one that Zesty designed so I may do a combination of one fan mounted that way with a ring attached to the bottom and then have another fan mounted on one of the other sides of the effector and use it's attachment points to stabilize that end of the ring so it doesn't bounce around and is rigid. Thinking of either doing a simulation in Fusion 360 or just printing it and maybe testing with a vape stick to see how the air flows.
Instagram
Twitter
April 03, 2020 07:02PM
I think that's a good idea. I already printed the Zesty 5015 fan duct and the weight was 20.48g. One 5015 blower fan weighs 28.34g ( I ordered mine today) . Isn't to much weight with 2 blowers ? What do you think?
Edited 1 time(s). Last edit at 04/03/2020 07:04PM by alex773.
open | download - IMG_20200403_173221.jpg (228.8 KB)
April 03, 2020 07:03PM
It might be too much. One is probably enough. I’ve even been looking into 40mm or 30mm blower fans.
Instagram
Twitter
April 03, 2020 07:09PM
Did you see this one ? 11.89g
[www.thingiverse.com]
Edited 1 time(s). Last edit at 04/03/2020 07:14PM by alex773.
open | download - IMG_20200403_173304.jpg (238.5 KB)
open | download - IMG_20200403_181055.jpg (206.9 KB)
April 06, 2020 09:49PM
I finally found a way to install the Zesty fan duct as you can see in the picture. By mistake I make a short between the legs of the blower fan. Now the lights, heatsink fan and the cooling fan for Duet board are not working. There is any fuses for Duet or smart effector ? Please let me know how to do troubleshooting . Thank you. I can't believe this.
Edited 1 time(s). Last edit at 04/06/2020 10:16PM by alex773.
open | download - IMG_20200406_201721.jpg (235.4 KB)
April 07, 2020 01:39AM
Which Duet is is it? Duet WiFi/Ethernet revision 1.03 and later have a 1A blade fuse for the fan supply.
April 07, 2020 07:45AM
Thank you David for your reply.
I have a Duet2 WIFI V1.04a. I found the fuse and I'm on my way to the store. Probably they are not going to have a 1A but I found your post where you said I can use a 2A fuse. Thank you
Edited 1 time(s). Last edit at 04/07/2020 08:54AM by alex773.
April 07, 2020 03:53PM
My printer is up and running. Thank you David
April 10, 2020 10:24AM
I’m curious how the new cooling has affected print quality.
Instagram
Twitter
April 10, 2020 12:31PM
I never had the chance to use it. It takes to much from the build plate, I can't use G32 . The blower fan is hitting the Y tower during the auto calibration. The bracket it has to be modified to fit the smart effector. I printed this duct : [www.thingiverse.com] 270 degrees and give it a try. I will post some pictures today.
Did you change your cooling system ? I ordered some 4010 blower fan to try them out.
April 10, 2020 01:42PM
I haven’t had the chance to try new cooling. I just stared a new job and haven’t settled yet. I did see that the fan hangs out pretty far. I was probably only going to use it’s mounting method. I’m thinking of doing a couple of 4010. I also found that SeeMeCNC has 3010 for sale. I was thinking of trying a couple of those. Maybe with either a circular cooler like the Zesty one you printed or something like this one.
https://www.sublimelayers.com/2017/10/tusk-part-cooling-for-titan-aero-and.html?m=1
Edited 1 time(s). Last edit at 04/10/2020 01:43PM by blt3dp.
Instagram
Twitter
April 10, 2020 04:48PM
This design looks promising. I like the tusk very much. I think Filastruder have the 3010 fans also. I don't know how easy is to find the tubes
April 10, 2020 04:56PM
I would have thought to find the tubes at a hobby shop but they’re all probably closed. Maybe something compatible can be found at a hardware store. I know Lowe’s and Home Depot are open. I’ll see if I can get a design drawn up to work with the smart effector.
Instagram
Twitter
April 10, 2020 05:43PM
This post by DjDemonD is interesting.
https://reprap.org/forum/read.php?178,794415,796026#msg-796026
Instagram
Twitter
April 10, 2020 05:59PM
There is another set up like this on Thingiverse with 2X4010 fans. Did you see it ?
April 10, 2020 06:02PM
I haven’t, have a link?
Instagram
Twitter
April 10, 2020 06:23PM
There is one : User name : Juggeli
[forum.duet3d.com]
I'm looking right now for the link from Thingiverse.
Edited 1 time(s). Last edit at 04/10/2020 06:29PM by alex773.
April 10, 2020 06:27PM
April 11, 2020 08:38PM
I did modified the 270 degrees fan duct and this is the result. This is the best print.
open | download - IMG_20200411_192253.jpg (158.1 KB)
open | download - IMG_20200411_192543.jpg (190.9 KB)
open | download - IMG_20200411_192552.jpg (190.8 KB)
open | download - IMG_20200411_192951.jpg (203.5 KB)
April 11, 2020 09:14PM
The bow looks pretty good, as does most of the rest of it I think. Looks like there’s some stringing. That’s probably a temperature or retraction setting. I think the temperature is probably good cause I had it set for 185 in that code. The retraction you may want to be more. I know you use Simplify3d, but I sliced those in Prusa Slicer. I can send you my profiles and you can tweak with them to get the stringing taken care of then translate the settings to Simplify. I’d almost say maybe stick with Prusa Slicer because you can set it up for firmware retraction and tweak it while the print is going.
Instagram
Twitter
April 11, 2020 10:12PM
What version of prusa slicer you have ? V 2.2 ?
