Re: Kossel Delta xxl build project HELP
July 13, 2020 07:13PM
It shouldn't matter as long as they're next to each other and the same on both ends. Now if it were something like black, blue, green, red you would need to make a change. But you're ok.
Edited 1 time(s). Last edit at 07/13/2020 07:39PM by blt3dp.
My 3D Printing YouTube Channel
Better Living Through 3D Printing
Follow me on Instagram and Twitter
Instagram
Twitter
July 13, 2020 08:47PM
I plugged the cable like you said and when it was not extruding it was making a noise and a big vibration. Then I changed the red with blue and now the noise is like a whistle but no vibration. No gears are moving inside, just the noise. I don't remember to have any noise from the Extruder motor of the Nimble when it was not extruding.
Edited 1 time(s). Last edit at 07/13/2020 08:51PM by alex773.
July 13, 2020 08:52PM
Ah crap, i forgot on the hemera side it's one of those 6 pin connectors but there's a couple of empty ones and they're in weird places. You might have to use a multimeter. Regardless of how they're connected on the motor end, when you multimeter it out, on the other end pins 2 pins should say they're connected to each other. They go next to each other in the connector. The other 2 take up the other spots.
Edited 1 time(s). Last edit at 07/13/2020 08:58PM by blt3dp.
Instagram
Twitter
July 13, 2020 09:08PM
This is what I have on the Hemera side.
open | download - IMG_20200713_195842.jpg (239.9 KB)
July 13, 2020 09:13PM
Yeah, I'm actually using the one from the Titan i had since it was already nicely cable tied. The one that I have that came with the Hemera is the same. Looking at the data sheet, on the end that plugs into the Duet you will want is red,blue,green,black. Which i'm pretty sure is how I have mine setup.
https://e3d-online.dozuki.com/Document/GdYIUZMlaEoWbQhU/Hemera-Datasheet-%28Edition-2%29.pdf
Make sure you have the current set to around 1100 in M906 in your config.g
Of course don't try to extrude unless it's hot.
Edited 5 time(s). Last edit at 07/13/2020 09:16PM by blt3dp.
Instagram
Twitter
July 13, 2020 10:16PM
I did multimeter it out and I have red and blue , first 2 pins and green and black the other 2 pins connected to each other.This is what I have in Config.g for M906:
M906 X1000.00 Y1000.00 Z1000.00 E500.00 I35 ; Set motor currents (mA) and motor idle factor in per cent
Should I change E500 to E1100 and try again ?
Edited 2 time(s). Last edit at 07/13/2020 10:30PM by alex773.
July 13, 2020 11:10PM
This is how I connected the cable to the Duet. It is not vibrating anymore but I still have that whistle noise.
This is my M906 now :
M906 X1000.00 Y1000.00 Z1000.00 E1100.00 I35 ; Set motor currents (mA) and motor idle factor in per cent
Edited 1 time(s). Last edit at 07/13/2020 11:11PM by alex773.
open | download - IMG_20200713_220650.jpg (367.6 KB)
July 14, 2020 01:51AM
Swapping the red and blue wires over will reverse the direction of movement of the motor. That's all.
July 14, 2020 09:41AM
Thank you David. My concern is that buzzing/whistle sound from the motor when is not extruding.
July 14, 2020 09:49PM
I'm about to turn on the printer and start using the Hemera. What Retraction Length you are using ?
July 14, 2020 09:55PM
That’s the M207 command I posted earlier.
I use 3.5mm @ 40mm/sec
Instagram
Twitter
July 14, 2020 10:09PM
Thank you. Hopefully I finish today and print something tonight. I'm so curious about Hemera.
July 20, 2020 06:55PM
This is the Thin Wall test cube- 0.4mm sliced with Prusa Slicer. The wall thickness is 0.5. please see the attached pictures.
open | download - IMG_20200720_175055.jpg (188.9 KB)
open | download - IMG_20200720_175027.jpg (228.2 KB)
open | download - IMG_20200720_174432.jpg (131.2 KB)
open | download - IMG_20200720_174418.jpg (138.1 KB)
open | download - IMG_20200720_174357.jpg (137.5 KB)
July 20, 2020 07:16PM
Looks like it's starving for filament on layer starts. In PrusaSlicer, on the Printer Settings Tab under Extruder 1, I have the option "Retract on layer change" unchecked.
I also on the Printer Settings Tab under General, I have it setup like this.
And lastly, I have that M207 command in my config.g
I like Firmware Retraction because you can adjust it on the fly just by sending the M207 again.
I would say print a cube, but stretch it taller and tweak the retraction until the start of the lines are good.
I'm also concerned about the wavy corner on that one shot. Is that corner facing a particular tower?
Edit: Or is that wavy corner the one with the starved starts?
Edited 1 time(s). Last edit at 07/20/2020 07:20PM by blt3dp.
Instagram
Twitter
July 20, 2020 07:46PM
I did all the modification you suggested in Prusa and the cube 0.4mm it's looking good now. The walls are still 0.5mm thick. I do have the M207 command in my config.g
Edited 1 time(s). Last edit at 07/20/2020 07:54PM by alex773.
open | download - IMG_20200720_184733.jpg (149.9 KB)
open | download - IMG_20200720_184719.jpg (135.4 KB)
open | download - IMG_20200720_184707.jpg (144.5 KB)
July 20, 2020 08:52PM
This is the test stretched taller to 30mm. The walls thickness is still 0.5mm
open | download - IMG_20200720_194836.jpg (166.6 KB)
open | download - IMG_20200720_194826.jpg (153.2 KB)
open | download - IMG_20200720_194811.jpg (154.1 KB)
July 20, 2020 09:16PM
In order to use the retraction on the fly from 3.5 to 4.2 I have to send M207 S4.2 F2400 Z0.00 ? I never used the M207 command. Thank you
July 20, 2020 09:47PM
Yep, that’s what you’d send.
Instagram
Twitter
July 20, 2020 09:55PM
My Bowden tube is 660mm and I use 4.6 retraction and I'm getting a horrible stringing. I will try retraction on the fly and hopefully I can adjust it.
July 20, 2020 09:59PM
Maybe temperature or movement speed. Does it move pretty quickly between points where it retracts and begins again.
Instagram
Twitter
July 20, 2020 10:05PM
I start a print with 205c first layer then I drop the temperature to 195, 190c. The speed I think is 40mm
July 21, 2020 08:28AM
My Hemera is doing a click when is retracting. I checked the gears alignment and everything is good. I released the tensioner all the way then I tight it up again and I still have that click. I don't know if is normal to do that.
VDX
July 21, 2020 11:02AM
... a single "click" could be mechanical play on one of the wheels ... could even be the stepper rotor, what's rocking with direction changes between two positions ...
Viktor
July 21, 2020 11:24AM
Thank you Viktor. I will open up the gear box and check for any play and report back
July 21, 2020 12:22PM
I'm wondering if it's too much as in when it retract it's pulling hot filament into the cold section and cooling it causing a temporary jam. Maybe the clicking is the gear teeth riding over the imprints it already had made.
Is there filament powder on the gears when you took it apart?
I'd also be curious if it's skipping steps on the retract because it's too much for it. On the side of the Hemera there's an exposed section of the gear, watch it when it retracts. It should jump back really quickly when it does the retract. Watch it and see if it jumps forward at all when it should be retracting.
I bet it's too much retraction, there are all kinds of recommendations out there on how much per whatever measurement of the bowden tube. It's all very inexact. People used to do massive retractions because of the perceived play in the bowden setup. Our setups with the Capricorn tubes, Hemera, and e3D Hotends are fairly well constrained. I'm betting you don't need 4.6mm.
You might try lowering the retraction distance and/or speed. It's the F parameter in your M207. Try dropping it a little at a time, I wouldn't drop it below 1800 though.
I've found it's somewhat trial and error to find the point where you're using retraction to prevent stringing as well as finding the quickest movement speed possible to also prevent stringing. There's no sense in retracting whatever amount if the printer moves slowly enough that it is still able to ooze out of the hotend before it can reach where it needs to extrude next.
I wonder if maybe it's your acceleration,
Here's the drives section of my config.g,
; Drives
M92 X200.00 Y200.00 Z200.00 E409.00                       ; set steps per mm
M566 X600.00 Y600.00 Z600.00 E3600.00                     ; set maximum instantaneous speed changes (mm/min)
M203 X7200.00 Y7200.00 Z7200.00 E7200.00                  ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E7200.00                  ; set accelerations (mm/s^2)
M906 X1700 Y1700 Z1700 E1100 I30                          ; set motor currents (mA) and motor idle factor in per cent
M84 S30                                                   ; Set idle timeout
My maximum speeds for everything are 120 mm/sec, in PrusaSlicer, I have the movement speed set to 90 mm/sec
You can see the max instantaneous speed change (jerk) and acceleration for my extruder are way higher than everything else.
Maybe ensure those aren't crazy high.
Instagram
Twitter
July 21, 2020 12:59PM
M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation
M92 X200.00 Y200.00 Z200.00 E409 ; Set steps per mm
M566 X600.00 Y600.00 Z600.00 E3600.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X7200.00 Y7200.00 Z7200.00 E7200.00 ; Set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E7200.00 ; Set accelerations (mm/s^2)
M906 X1700.00 Y1700.00 Z1700.00 E1100.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
The F parameter in M207 is 2400. I will change it to F2300.
There is no filament powder on the gears.
Edited 1 time(s). Last edit at 07/21/2020 01:00PM by alex773.
July 21, 2020 01:02PM
Yeah, it should be just like mine. I'd try out different speeds and distance combinations of M207
Instagram
Twitter
July 21, 2020 01:13PM
This are my speeds PrusaSlicer
open | download - Screenshot (29).png (124 KB)
July 21, 2020 01:19PM
I don't see anything there so different than mine. Except the travel speed, I have it set lower at 90 mm/sec. The Max Print Speed I left at default 80 mm/sec
Instagram
Twitter
July 21, 2020 01:23PM
I will change this 2 speeds and print something to see
