Prints from new Delta not square March 25, 2019 11:48AM |
; Configuration file for Duet WiFi (firmware version 1.17 to 1.19) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2 on Sun Jan 20 2019 07:13:04 GMT-0800 (PST) ; General preferences G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M665 R165.000 L333.886 B145.000 H363.920 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them ; Network M550 P"My Printer" ; Set machine name M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drives M569 P0 S1 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation M92 X200.00 Y200.00 Z200.00 E837.00 ; Set steps per mm M566 X1200.00 Y1200.00 Z1200.00 E120.00 ; Set maximum instantaneous speed changes (mm/min) M203 X7200.00 Y7200.00 Z7200.00 E7200.00 ; Set maximum speeds (mm/min) M201 X3000.00 Y3000.00 Z3000.00 E200.00 ; Set accelerations (mm/s^2) M906 X1100.00 Y1100.00 Z1100.00 E900.00 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 Z0 S1 ; Set minimum Z ; Endstops M574 X2 Y2 Z2 S1 ; Set active high endstops ; Z-Probe M558 P8 R0.4 H5 F300 I1 T1800 ; Set Z probe type to effector and the dive height + speeds G31 P500 X0 Y0 Z-0.1 ; Set Z probe trigger value, offset and trigger height M557 R106.066 S20 ; Define mesh grid ; Heaters M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit M305 P0 T100000 B3950 R4700 ; Set thermistor + ADC parameters for heater 0 M143 H0 S130 ; Set temperature limit for heater 0 to 120C M305 P1 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1 M307 H1 A417.2 C302.9 D6.9 S0.70 V24.4 B0 ; Set PID parameters for heater 1 M143 H1 S290 ; Set temperature limit for heater 1 to 285C ; Fans M106 P1 T45 H1 ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Custom settings are not configured
Re: Prints from new Delta not square March 26, 2019 05:35AM |
Re: Prints from new Delta not square March 26, 2019 09:55AM |
Re: Prints from new Delta not square April 03, 2019 09:57AM |
Re: Prints from new Delta not square April 03, 2019 08:00PM |
Re: Prints from new Delta not square April 04, 2019 03:00AM |
Re: Prints from new Delta not square April 04, 2019 09:43AM |
Re: Prints from new Delta not square April 15, 2019 12:41PM |
Re: Prints from new Delta not square April 15, 2019 04:30PM |
Re: Prints from new Delta not square April 15, 2019 04:46PM |
Re: Prints from new Delta not square April 15, 2019 10:28PM |
Re: Prints from new Delta not square April 17, 2019 08:56PM |
