Delta Motion Uneven
Posted by wheemzy
Delta Motion Uneven
April 11, 2019 11:18AM
Hello,
I used two different levels so I am pretty sure the print bed is even. Yet, when I jog the hot end around the print area I notice that the hot end travels up in the Z-direction fairly substantially (a few millimeters) when traveling in the Y direction. I changed the endstops and that did not make a difference.
Does anybody know what is happening?
Thanks for any input...
Edited 1 time(s). Last edit at 04/11/2019 11:19AM by wheemzy.
Re: Delta Motion Uneven
April 11, 2019 12:01PM
How did you calibrate the endstops? Are you sure nothing changed? because that would be weird.
Also do you plan on using any autocalibration?
If however youre describing the koncave or konvex motion then your delta radius is probably the culprit.
April 11, 2019 12:58PM
That did the trick. It was the radius parameter. Thanks!
Edited 1 time(s). Last edit at 04/11/2019 12:59PM by wheemzy.
April 11, 2019 02:00PM
If you are calibrating manually this tool takes a little while, but it is absolutely indispensable:
Delta Printer Least-Squares Calibration Calculator
