Magentic Ball Joints - alternate rod ends May 16, 2019 06:55AM |
Re: Magentic Ball Joints - alternate rod ends May 16, 2019 09:51AM |
Re: Magentic Ball Joints - alternate rod ends May 16, 2019 11:21AM |
Re: Magentic Ball Joints - alternate rod ends May 16, 2019 11:41AM |
dc42
I think you will find that the cost of 12 of the smallest/cheapest of those joints exceeds the cost of a set of 6 rods form Haydn. Although you might save a little on carriage.
You can buy Haydn's rods in one particular length from the UK at [www.duet3d.com]. I don't know whether the shipping would cost any less than from Haydn direct.
Re: Magentic Ball Joints - alternate rod ends May 16, 2019 11:51AM |
leadinglights
If you are on a really tight budget it is not too expensive to make your own. Magnets and steel balls are quite inexpensive and all you need to make are the bits to hold them all together. make the cups out of Delrin, Nylon or bronze - DO NOT MAKE THE CUPS OUT OF STEEL - that way lies only a deeper understanding of magnetic circuits and that what is obvious really aint so.
I made mine with woven carbon fibre rod - often sold for making model aircraft. The cups and magnets are held on to the CF rods with epoxy in a 10mm OD brass tube and all parts are given a false thread to give the epoxy a bit of grip. The cups should hold the magnet very close to the ball without touching - say 0.25 to 0.5mm.
Do make a jig to get the lengths of all of the tubes as close to identical as possible.
Mike
Re: Magentic Ball Joints - alternate rod ends May 16, 2019 12:12PM |
Re: Magentic Ball Joints - alternate rod ends May 17, 2019 03:15AM |
leadinglights
Although I do have access to machining facilities I did not need them for making the rods. Try using your ball nose milling cutter to cut a recess in the end of a delrin rod then file to fit. The most important thing is to get the length ball to ball the same on every one. It is also not usually necessary to have angled balls - see DC42s smart effector where all of the balls are straight.
Mike
