Bringing my DreamMaker Overlord Pro back to life; rebuild... August 26, 2019 05:33PM |
Re: Bringing my DreamMaker Overlord Pro back to life; rebuild... August 27, 2019 02:47AM |
Re: Bringing my DreamMaker Overlord Pro back to life; rebuild... August 27, 2019 04:50AM |
Re: Bringing my DreamMaker Overlord Pro back to life; rebuild... August 27, 2019 05:06AM |
Re: Bringing my DreamMaker Overlord Pro back to life; rebuild... August 27, 2019 05:44AM |
Re: Bringing my DreamMaker Overlord Pro back to life; rebuild... August 27, 2019 06:07AM |
hercek
Ok, if by A=0 you meant where is zero position on delta coordinate A, then it is at the heat bed level. Delta coordinates have 0 at the bed level and maximum (printer height) at the max endstop level; i.e. delta coordinates have maximum values after homing.
Re: Bringing my DreamMaker Overlord Pro back to life; rebuild... September 01, 2019 01:21PM |
Re: Bringing my DreamMaker Overlord Pro back to life; rebuild... September 01, 2019 05:39PM |
Re: Bringing my DreamMaker Overlord Pro back to life; rebuild... September 01, 2019 05:59PM |
hercek
If one fan is cooling heat-break on the hotend then that is the one which should run at full throttle all the time.
The fan which is supposed to cool the printed part is the one which speed can be controlled from the firmware/gcode.
Re: Bringing my DreamMaker Overlord Pro back to life; rebuild... September 02, 2019 02:14PM |
Re: Bringing my DreamMaker Overlord Pro back to life; rebuild... September 08, 2019 10:16AM |
Re: Bringing my DreamMaker Overlord Pro back to life; rebuild... September 08, 2019 12:32PM |
Re: Bringing my DreamMaker Overlord Pro back to life; rebuild... September 08, 2019 03:02PM |
Re: Bringing my DreamMaker Overlord Pro back to life; rebuild... September 10, 2019 02:39PM |
