Z0 and the result
Posted by PastorHealer
Z0 and the result
September 09, 2019 06:08PM
Delta K200 Printer
Z0 is set at .1 above the glass bed
Z Probe Height is at 5.5
Z Height 303.350
When I check Z0, I have the nozzle set to be at .1 above the glass. And that is where the nozzle lands.
I check the 3 outer coordinates for nozzle height and all is fine. The nozzle is within .02 at each location.
Then the wheels fall off...
When I use G32 S2 P0, the probing changes the bed height by .77mm's.
If I use G32 S1 P0, nothing changes, but the Delta printer becomes a glass cutter instead of a printer.
Clear S2 changes the bed height by the .77, but why is it doing this and where is that number coming
from?
As well, if I use the S1 attribute, while the bed height doesn't change, the glass cutter affect is still in
play.
What am I doing wrong in getting a print started?
