Delta printer ball joints, let's talk! November 04, 2019 04:15AM |
Re: Delta printer ball joints, let's talk! November 04, 2019 06:49AM |
Re: Delta printer ball joints, let's talk! November 04, 2019 07:02AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Delta printer ball joints, let's talk! November 04, 2019 11:05PM |
Re: Delta printer ball joints, let's talk! November 04, 2019 11:19PM |
Re: Delta printer ball joints, let's talk! November 05, 2019 01:24PM |
Re: Delta printer ball joints, let's talk! November 05, 2019 04:29PM |
Re: Delta printer ball joints, let's talk! November 05, 2019 04:31PM |
Re: Delta printer ball joints, let's talk! November 06, 2019 06:07AM |
Re: Delta printer ball joints, let's talk! November 07, 2019 11:03PM |
Re: Delta printer ball joints, let's talk! November 08, 2019 01:37AM |
Re: Delta printer ball joints, let's talk! November 08, 2019 06:09PM |
Re: Delta printer ball joints, let's talk! November 15, 2019 06:09PM |
Re: Delta printer ball joints, let's talk! November 16, 2019 02:23PM |
Re: Delta printer ball joints, let's talk! December 03, 2019 10:11PM |
Re: Delta printer ball joints, let's talk! December 05, 2019 02:02AM |
Re: Delta printer ball joints, let's talk! December 05, 2019 05:06AM |
Re: Delta printer ball joints, let's talk! December 05, 2019 06:19AM |
hercek
Magnets give zero backslash only when they are strong enough or your accelerations are low enough. Ball joints give you zero backslash regardless of accelerations if you are willing to buy good ones and replace them over time. Choose your poison!
It depends on what accelerations you want to print with.
Re: Delta printer ball joints, let's talk! December 05, 2019 02:25PM |
Re: Delta printer ball joints, let's talk! December 06, 2019 05:48AM |
Re: Delta printer ball joints, let's talk! December 06, 2019 07:32AM |
Re: Delta printer ball joints, let's talk! December 06, 2019 10:51AM |
Re: Delta printer ball joints, let's talk! December 07, 2019 02:33AM |
Re: Delta printer ball joints, let's talk! December 07, 2019 02:15PM |
hercek
Re: Delta printer ball joints, let's talk! December 09, 2019 05:04AM |
Thanks for your update.Quote
I wonder what it will take me to injection mold them of POM or PTFE
Re: Delta printer ball joints, let's talk! December 10, 2019 04:12AM |
Re: Delta printer ball joints, let's talk! December 10, 2019 06:21AM |
3Dpassion
3D Printing the cage isn't worth it imo. Will be crazy inaccurate. As a side note, I received those plastic joints on Friday and I am not sure what's the bad feedback is about, they are actually extremely solid and there is definitely zero backlash in them, super light too. With that said, M3 screw obviously will not secure that joint correctly, it needs a proper install, probably with M2 screw and a spacer instead to make it all tight.
Re: Delta printer ball joints, let's talk! December 11, 2019 05:07PM |
Re: Delta printer ball joints, let's talk! December 18, 2019 04:40PM |
Re: Delta printer ball joints, let's talk! December 24, 2019 06:43AM |
