FLsun Kossel Calibration Second Thread December 18, 2019 11:12AM |
Re: FLsun Kossel Calibration Second Thread December 18, 2019 03:32PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: FLsun Kossel Calibration Second Thread December 18, 2019 04:45PM |
Re: FLsun Kossel Calibration Second Thread December 20, 2019 02:58PM |
Re: FLsun Kossel Calibration Second Thread December 20, 2019 07:49PM |
Re: FLsun Kossel Calibration Second Thread December 21, 2019 05:53PM |
Re: FLsun Kossel Calibration Second Thread December 21, 2019 07:11PM |
Re: FLsun Kossel Calibration Second Thread December 22, 2019 01:18AM |
Don't bother! Difference of only 1.8 % in diagonal rod length does not matter at all provided you have the correct rod length filled in in your printer configuration in firmware. When I talked about errors in my previous post, I talked about errors in the printer dimensional specification in the firmware with respect to the mechanical reality. I did not talk about errors against what FLsun mechanical drawings specify.Quote
NAP1947
The big point I get from your explanation is the rods not only need to equal in length but not overly long.
The FLsun spec calls for 218mm rods, mine are 222mm. So if I shorten the rods to 218MM it may reduce some of my error
This is a big problem! In-equal distance between rod ends on platform and the corresponding carriage leads to platform rotation during its horizontal movements. This will not have a big impact on Z-error but it will screw up your XY-error big time. And if such a mechanical "slip" results in an increase of unwanted play (e.g. a possibility of slight movement of a ball in respect to the platform it is mounted on) then you are completely screwed up. Do not even bother to start calibrating your printer if some unwanted mechanical play is not fixed first!Quote
NAP1947
I was also found today that one of the rod connections on the effector has slipped and was wider than it should be so I will fix that as well.
Well, there is a good side of it as well. If you enjoy a bit of simple math and playing with your printer mechanics then you will get a lot of fun calibrating it. And it will work really well in the end. 8bit electronics can drive a delta printer easily. The only real problem with it is that there is no good automatic calibration for it in the firmware. linDeltaCalib project will help you calibrate it even better than what is possible with RepRap firmware and 32 bit Duet electronics ... if you can handle the math. That is because it is not all implemented in some pretty PC application which would lead users step by step and automate whatever is possible to automate. The calibration can be implemented at the same level as RepRap/Duet firmware does it. The problem is that nobody bothered to do it for 8-bit MCUs.Quote
NAP1947
I might have been better with a higher quality printer but that was all the budget could manage at the time
Re: FLsun Kossel Calibration Second Thread December 22, 2019 05:53AM |
Re: FLsun Kossel Calibration Second Thread December 22, 2019 08:23AM |
Re: FLsun Kossel Calibration Second Thread December 23, 2019 02:38AM |
Re: FLsun Kossel Calibration Second Thread January 03, 2020 02:43PM |
Re: FLsun Kossel Calibration Second Thread January 14, 2020 04:37PM |
