I am working on a delta with a Chimera+ hotend installed. Each nozzle is +-10mm on the X axis from the center of the effector. Marlin disallows setting the offset of E0 to anything other than 0,0. So I have resorted to setting offsets in Marlin to 0,0 for both nozzles but then setting the nozzle offsets in Cura. If I understand this correctly, this means Marlin will have no idea where the active nozzle actually is and any Z offsets from the bed leveling routine will be applied at the center of the effector not where the nozzle is actually located.
Am I thinking this through correctly? Would this issue also impact any corrections that Auto Calibration applies?
Thanks!
