Delta printing undersized May 19, 2020 04:08PM |
//============================== Movement Settings ============================
// @section motion
* Default Settings
* These settings can be reset by M502
* Note that if EEPROM is enabled, saved values will override these.
* With this option each E stepper can have its own factors for the
* following movement settings. If fewer factors are given than the
* total number of extruders, the last value applies to the rest.
//#define DISTINCT_E_FACTORS
* Default Axis Steps Per Unit (steps/mm)
* Override with M92
* X, Y, Z, E0 [, E1[, E2[, E3[, E4]]]]
// #define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 80, 98 } // This is no longer used in Marlin 1.1.9 - it is now calculated below
* Override with M92
// variables to calculate steps
#define XYZ_FULL_STEPS_PER_ROTATION 200 // These are the setting for the stock Stepper Motors, pulleys and Belts on the AnyCubic Kossel
#define XYZ_MICROSTEPS 16
#define XYZ_BELT_PITCH 2
#define XYZ_PULLEY_TEETH 20
Re: Delta printing undersized May 19, 2020 09:17PM |
Re: Delta printing undersized May 20, 2020 05:18AM |
Re: Delta printing undersized May 24, 2020 07:35AM |
