How to change configuration to a delta robot not a printer? January 05, 2021 07:20AM |
Re: How to change configuration to a delta robot not a printer? January 06, 2021 03:52AM |
Re: How to change configuration to a delta robot not a printer? January 08, 2021 07:42AM |
dc42
You need to run firmware that supports Rotary Delta kinematics. RepRapFirmware does, see [duet3d.dozuki.com]. Maybe there is a fork of Marlin that does.
The calculations for Rotary Delta kinematics involve trigonometry, so you should use a controller with a fast processor and hardware floating point. Calibration can be tricky because there are so many parameters to set - not a problem for a well-manufactured commercial machine for which the parameters are known, but harder for DIY machines.
Re: How to change configuration to a delta robot not a printer? January 18, 2021 10:20PM |
