David i need some help understanding the z triggered height
So my question is a mathematics one sort of.
On the documentation is says that i need to specify the triggered height for the center of the bed and then every point on my bed config.
So the H parameter says it is triggered height at a point minus the triggered height on the center of the table .
That means that if i have a triggered height -0.10 on the X0Y0 and -0.30 at a specific point X0Y128 the nnn is -0.40 ? Am i doing it right or i am on a wrong path ?
Secondly during the procedure you saying that i have to set Z0 with G92 and then get up on Z 5mm and do a G30 S-1. Is this something that i have to do for all the bed points or do i keep the center G92 Z0 and just doing only G30 S-1 on the other points ?
I wrote on the duet3d but you probably miss it ...
Delta Printer
Duet 0.8.5 firmware 1.19
