Delta home issue July 21, 2021 07:37PM |
Re: Delta home issue July 22, 2021 08:43AM |
Re: Delta home issue July 22, 2021 05:52PM |
Re: Delta home issue July 23, 2021 02:35PM |
Re: Delta home issue July 24, 2021 07:25AM |
Re: Delta home issue July 24, 2021 02:22PM |
Re: Delta home issue July 24, 2021 08:14PM |
Re: Delta home issue July 25, 2021 05:49PM |
Re: Delta home issue July 26, 2021 02:31PM |
Yes having issues as well.. the endstops and motors match I'm just confused on why it can't do a simple home all hit the top endstops then lower to Z_Min if it lowers for a home all it just crashes in the bed hard while dragging the nozzle towards the Z motor.Quote
jcs
So with Repetier you're not having any problem???
Re: Delta home issue July 27, 2021 12:09PM |
Re: Delta home issue July 27, 2021 05:52PM |
Re: Delta home issue July 27, 2021 07:33PM |
The stock marlin firmware that came with it caused it to home downwards (never touched the top endstops) that's when I knew something was not right.. one of the firmwares I tried the Y motor never moved.. but switching back to another firmware it did... must be something amiss in that one.Quote
leadinglights
@MikeCL. Can we look at what is happening one item at a time. Ignoring G0 Z whatever for the moment and concentrating on the "Home All" button or perhaps G28.
- Does the effector home in an upward direction?
- After reaching all three limit switches, does it do a little dance, going down a couple of mms and then slowly up again to home?
- Does the display or control program show that the Z value is now at maximum? For example, Z=303mm or whatever
Mike
Re: Delta home issue July 28, 2021 11:28AM |
Re: Delta home issue July 28, 2021 12:53PM |
Re: Delta home issue July 29, 2021 01:30PM |
Re: Delta home issue July 30, 2021 06:15PM |
Re: Delta home issue July 30, 2021 09:02PM |
Re: Delta home issue July 31, 2021 09:46AM |
Re: Delta home issue July 31, 2021 10:57AM |
Re: Delta home issue July 31, 2021 01:03PM |
I think it was like 580 after the homing I did not do a G0 Z20 I did G0 Z0 but I can try thatQuote
leadinglights
What value for Z does it show on the display immediately after homing? It should show the maximum possible Z value - i.e., the height from the bet to the nozzle tip when homed.
Do I understand correctly that doing something like "G0 Z20" does not result in the effector moving down?
Mike
Re: Delta home issue July 31, 2021 02:06PM |
Re: Delta home issue July 31, 2021 07:56PM |
Re: Delta home issue August 01, 2021 06:20PM |
Re: Delta home issue August 01, 2021 08:02PM |
Re: Delta home issue August 04, 2021 02:52PM |
MikeCL
Yeah that part worked right now I’m trying to dial in the printer it looks like the nozzle is too close trying to adjust on the fly is not a good as I had with the anet a8 the extruder is skipping at some parts but not all if I lower the bed too much then it just make the ridges on the first layer but not that high to be air printing.
Re: Delta home issue August 04, 2021 03:11PM |
Re: Delta home issue August 04, 2021 04:03PM |
Re: Delta home issue August 07, 2021 08:52PM |
