Looking for some guidance on heated beds August 24, 2021 07:50PM |
Re: Looking for some guidance on heated beds August 25, 2021 02:16AM |
Re: Looking for some guidance on heated beds November 29, 2021 02:52PM |
My printer is an HE3D K280 with 290 mm heated bed. It also uses a glass plate over the painted aluminum bed plate and the combination gives a 280 mm print diameter.Quote
sircastor
Hello All,
I have owned a scaled up self-built kossel mini for a very long time (700mm tall, 360mm extrusions), and I've been slowly upgrading various features on it. I've had a 310mm round Borosilicate glass bed to print on, supported by FSRs. This has worked fine for me as I've printed exclusively PLA, but I'm ready to try some other materials and have been interested in printing some ABS again (My first printer was a Makerbot Cupcake, which printed all the parts for this machine)
I'm a bit overwhelmed by the options available for replacing the bed. There are kapton heaters, silicone heaters, and PCB heaters. Glass beds, Steel beds, and special surfaces to help stick, Some have magnets, some don't. If I use a PCB, I need a heat spreader. If I use FSRs, I have to protect them from heat. If I switch to inductive sensors I have to use a non-glass bed. The list of course, goes on and on.
Because of the size of my printer (which seemed like a great idea at the time) my surface needs to be about 280mm diameter (my current plate is oversized). I've thought about just using a square bed, but I have plans to try and enclose everything eventually.
Does anyone have a delta heated build plate they love? Or just recommendations?
Re: Looking for some guidance on heated beds November 29, 2021 06:54PM |
Re: Looking for some guidance on heated beds December 09, 2021 01:28PM |
Re: Looking for some guidance on heated beds December 09, 2021 02:44PM |
