Anycubic delta bed mesh problem December 09, 2021 12:15PM |
Re: Anycubic delta bed mesh problem December 13, 2021 05:56AM |
Re: Anycubic delta bed mesh problem December 13, 2021 09:11AM |
hercek
It looks like your bottom left tower is nearer (or further depending on sign of the error in your charts) to the centre in reality when compared to the geometry data in the firmware.
Plus some slight rise of all edges up - that indicates small error in delta radius or diagonal rod.
If you can handle some math then this may help you: [github.com]
Re: Anycubic delta bed mesh problem December 13, 2021 10:04AM |
No firmware I'm aware of can calibrate out this kind of error. This error manifests itself more as XY dimensional inaccuracy than Z axe inaccuracy. To check for this use a bulls eye level on your platform. Check horizontal position at all places of your bed.|
Re: Anycubic delta bed mesh problem December 14, 2021 10:17AM |
Re: Anycubic delta bed mesh problem December 14, 2021 02:49PM |
Re: Anycubic delta bed mesh problem December 14, 2021 03:44PM |
hercek
The most easy and most costly solution is to update electronics and use RepRap firmware.
The most time consuming way is to use my stalled(*) Repetier branch and callibration.wxm. It is very likely you do not need any HW update but you need some math & firmware loading knowledge and free time to spend. I use it with an AVR board. All the added calibration stuff is not ported to DUE boards.
Re: Anycubic delta bed mesh problem December 15, 2021 09:07AM |
.. mainly when trying to do a bed level.|
Re: Anycubic delta bed mesh problem December 16, 2021 02:57PM |
Sketch uses 133930 bytes (52%) of program storage space. Maximum is 253952 bytes. Global variables use 5955 bytes (72%) of dynamic memory, leaving 2237 bytes for local variables. Maximum is 8192 bytes.2 kB for stack should be enough.
Re: Anycubic delta bed mesh problem February 13, 2022 03:30AM |
Pippy
Thank you again hercek.
We would love to dump marlin, it's really not very good these days, what with compile problems and such like.
I just need to find a board that would run the reprap firmware, we can't justify buying one of their boards for this cheap printer at the moment, the printer was faulty when we got it, needed repairing etc, no telling what it had gone through before arriving here.
