Auto Calibration probing failed - Delta Flsun Kossel
Posted by riggah
July 18, 2022 09:20AM
Hey guys!
I recently got an FLSun kossel delta.
It was a bit neglected, so I lube it down as well as upgraded to Marlin 2.1. I never dealt with Deltas before, only i3 and CoreXYs so I am still learning.
Please assist me.
I am trying auto calibration. It probes, however at some point it doesn't want to continue further. It stops to do it itself but if I hit the probe it registers and continues.
The board is: MKS gen L 1.0 with a4988x5
Video Link
The Marlin config is the default Delta FLSun Kossel template in Marlins config templates.
I will paste them here as well:
Default Configs (link)
TL: DR
The printer halts and never succeeds to calibrate by using the probe.
What am I missing..?
open | download - Configuration.h (118.3 KB)
open | download - Configuration_adv.h (178.6 KB)
Re: Auto Calibration probing failed - Delta Flsun Kossel
July 29, 2022 09:16AM
Line 965 in your config.h
You need a pull up for a probe usually.
It is inverted a few lines later, for logic. (Zero = triggered, positive pulled up voltage = not triggered). That may or may not be correct.
Edited 1 time(s). Last edit at 07/29/2022 09:17AM by DragonFire.
August 01, 2022 11:12PM
I have the same printer, with the stock probe a.k.a. the nozzle triggering an endstop switch when pushed.
The video link you posted seems to be dead, but I have had something similar happen to me before.
Ensure the probe (nozzle) endstop switch is actually clicking (opening/closing). I had to try it a few times to get it properly tensioned so that it would reliably open when it contacts the bed and to close again after lifting the head.
