I'm planning to build a new delta printer using some of spares parts that got from previous builts. The plan is using 6 nema 17 on bottom and top, controlling each axis using indepent drive on klipper. I will go rigid on the frame using something very similar to this [
www.thingiverse.com].
I've 260mm diameter bed. I've some doubts calculation the right length of horizontal extrusion and rods. I would like to get the bed resting on horizontal extrusions. I try to use that calculator [
danalspub.com] is great to get some visual understanding of the build. But i was hoping they would give me the right measurements based on my print area. Is there any tool or formula to give the mesure of extrusion and arms based on my print area? I know for linear rails the rule is less 100mm of the vertical extrusion. I really want the less footprint possible.
