Kossel, Z-Height if Calibration Cube is way too small
Posted by stang6t8coupe
January 11, 2023 12:44PM
Got my Problems with Delta Radius sorted out, Auto Calibrate is working now.
I printed the 20mm Calibration Cube. X and Y was at 20.05mm, but Z is at 16.5mm. How could that be possible? I thought rod length scales all the axis uniformly.
Thank you,
Adrian
Re: Kossel, Z-Height if Calibration Cube is way too small
January 11, 2023 01:14PM
Rod length only scales X and Y. Z scale is determined by the steps/mm setting of the tower motor drivers. Get the Z scaling right before you adjust the XY scaling.
Edited 2 time(s). Last edit at 01/11/2023 01:16PM by dc42.
