Megatronics v1.0 - Fully assembled retails at 59,99 plus 19% VAT 71,38 Euro, selling mine for 50 it's brand new, never plugged in or used.
Compression spring - 25MM - OD 10MM x 4 1 euro for the lot
1 Meter PTFE tubing, 2inner/4outer diameter 2 euro for it
Pneufit straight adaptor,1/8inx6mm x 2 3 euro for the lot
LM8UU bearings x 16 1$ each
Carbon tube ø 6/4 x 1000mm x 2 (so two lengths of 1 meter) 6 euro each meter for rostock delta
Rod ends, Revo (large) with hollow balls (TRX-5347) x 12 for rostock delta 6 euro for the lot
Genuine Gates GT3 belts, 1700 teeth 2MGT 6, GT2 and GT3 interchange, so it's the same thing. x 3 perfect for rostock delta, 9 euro each
About 500x T-slot nuts for 20x20 aluminum profile, like the ones used for mendelmax. 15 euro pr. 100
Belt guides, made on a lathe in aluminum and pressed onto a 608 bearing, only works for T2.5 belts, suitable for prusa's x 2 3 euro each
img855.imageshack.us]
Contact me via PM or email me at asgerthybogeertsen (at) gmail.com
items are located in Århus Denmark, but can ship internationally
