[Canada, US & worldwide] ecksbot DIY kits, hot ends, bearings, rods and more
Posted by eckertech
April 05, 2013 02:22PM
We have ecksbot DIY kits & fully assembled machines, custom all metal hot ends and conversion kits, 3mm ABS filament, Kapton sheets with adhesive backing, power supplies, stepper motors, eckstruder kits, plastic parts and much more.
Visit us at [www.eckertech.com] for more information.
[www.eckertech.com]
[blog.eckertech.com]
[forum.eckertech.com]
Re: [Canada, US & worldwide] ecksbot DIY kits, hot ends, bearings, rods and more
April 15, 2013 02:11PM
The ecksbot DIY kit has been packaged to EckerTech standards containing high quality components to match the high quality of EckerTech printed parts. From the EckerTech all metal hot-end to long lasting precision ground hardened chromed linear motion rod the ecksbot is designed for durability.
The average ecksbot user can assemble, calibrate and start printing within 2 days of receiving their kit.
For more information please visit, http://www.eckertech.com/ecksbot/.
[www.eckertech.com]
August 28, 2013 04:04PM
ecksbot Ramps 1.4 electronics
The ecksbot Ramps 1.4 electronics comes complete with wiring harness pre-soldered into the Ramps board. The attached wiring is pre sized and numbered for easy installation using the ecksbot wiring method (click here) and can also be used for other RepRap printers if you don't mind our wiring configuration and wire lengths.
What's included?
• Fully assembled RAMPS 1.4 built on a black PCB because it just looks better that way
• Arduino Mega 2560 with USB cord
• 4 Genuine DRV8825 Pololu's built on 4 layer, 2oz copper PCB's for better heatsinking
• 1 SD Ramps addon for autonomous printing (printer not attached, micro SD not included)
• Full ecksbot wiring harness
What's Recommended?
• We recommend adding terminal blocks to your order, option found above, if you prefer a screwdriver over a soldering iron smiling smiley. These terminal blocks are rated to 24 amp's and are perfect for connecting 2 wires together. We use these blocks in all of our kits and fully assembled machines. Remember to make sure that your connections are tight!
• We recommend a plastic housing for the electronics with a cooling fan and ventilation system. We have one in the works which will be made available at a later date for purchase on our website or downloadable through thingiverse.
[www.eckertech.com]
