This kit includes all the bolts, nuts, washers, threaded and smooth rod needed to build your Mendel. Most bolts, nuts, and washers come with a few extras in case one gets lost. The rods are nice and straight. It is all packed tight and ships well. All studding and bar length cut to +0.8mm , - 0.0mm ends ground and ready for use or filed further.
54 - M3 Cap Screw 20mm
5 - M3 Cap Screw 25mm
20 - M3 Nut
38 - M3 Nylok
105 - M3 Washer
28 - M4 Nut
130 - M4 Nylok
460 - M4 Washer
40 - M4 Cap Screw 16mm
2 - M4 Cap Screw 20mm
20 - 3/16" fender washer*
105 - M8 Nut
105 - M8 Washer
120 - M4 Cap Screw x 40mm
2 - Bearing, 8mm x 22mm x 7mm
48 - Bearing, 4mm x 13mm x 5mm
M8 zinc steel threaded rod -2 x 440. 6 x 370, 4 x 294, 2 x 355, 2 x 418, 2 x 330
8mm Stainless Steel, Precision Ground Bar - 2 x 495, 2 x 406, 2 x 330
* Using 3/16" x 3/4" fender washer to replace M5x20 mudguard washer
All threaded rod, nuts, and bolts are metric as required of the Mendel documents.
Price: $180US shipping calculation and sales at
http://ultimachine.com/content/mendel-hardware-kit
Best regards,
Johnny Russell
Full photo by here.
Edited 7 time(s). Last edit at 08/22/2010 08:02PM by johnnyr.
