Universal Paste Extruder for RepRap
Posted by richrap
April 06, 2012 07:15AM
Hello everyone, I have just posted a blog about a Universal paste extruder
It can be used for all sorts of things, Chocolate, Ceramic, silicone, solder paste, food etc.
All the files are up on thingiverse -
And a build video is here - if you want to build one.
Along with lots of other videos on my YouTube channel
Rich.
[richrap.blogspot.com]
Re: Universal Paste Extruder for RepRap
April 06, 2012 11:21AM
Amazing, well designed paste extruder. Fantastic!
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
April 07, 2012 07:31PM
Great stuff, nice concept to use the belt.
Random Precision
April 08, 2012 03:59AM
Great work.
Do you reverse the motor at the end of a run? Presumably the belt doesn't allow you to reverse the syringe, just release the pressure. Is that sufficient to stop the flow?
April 08, 2012 06:36PM
Thanks, yes, just releasing the pressure by stopping seems to work. I'm printing quite slow, using no reverse and with a moderate travel speed (~100mm/sec) I'm not seeing any significant ooze, just a little when using the needles, less when using just the syringe without a needle.
I didn't expect to be able to print the frog in Porcelain, but it worked quite well at slow print speeds (12mm/sec). It could be more problematic at higher printing speeds, a little reverse may also help then.
I'm trying finer needles at the moment, then I'll try speeding it all up and see what happens.
May 21, 2012 02:11PM
Wow, richrap, that's cool! Congratulations.
I've been wondering what was happening with the intriguing [email protected] (paste extruding) style printers which sort of seem to have disappeared. But now, thanks to your innovation it seems that we can have it all with our Reprap style printers! I enjoyed watching your videos as well -so did my 3 year old who is now demanding that we print chocolate bunnies with our Mendel!
Jacqueline
www.singularitymachine.com/blog
September 09, 2012 12:46AM
Has anyone experimented with acrylic paints?
March 04, 2013 07:03AM
Does anyone know if there is a variant on this that fits nicely to the RepRap Mendel X carriage.
I guess making an adaptor would not be too difficult, but I'd like to save myself a bit of time.
March 21, 2013 05:39AM
So, I've started an exercise to create a paste extruder body which is an easy fit to a Mendel RepRap pro X carriage.
I've used google sketchup to add a flange to the side with 4 x 3mm holes that align with the Mendel's X carriage mounting holes. I will post this STL on Thingiverse when I'm happy with it.
As this is my first run through the entire toolchain, drawing package -> slicer -> print this is taking a while.
I started off with slic3r, (latest version) and I was able to create all the gears but my modified body is quite strange. Viewing the slic3r g-code the flange which is about 4mm thick comes up to about layer 38 (.4mm layers).
Using SFACT I can get a printable part with a flange of the correct thickness but it does throw error messages about incomplete triangles up to about layer 38. The various layers look ok and this is very odd as the rest of the body is unchanged and the flange should be 4mm thick.
I tried using the freeware version of netfab to fix the stl, which it did, but resulting, repaired STL file is tiny compared to my original model file?!?!
I tried using cadspan the 'skin' the file but although it seems to be processed correctly I'm still getting warnings about incomplete triangles when SFACT runs.
Also, when the part is printed the holes in the flange come out smaller than in the model file, intended to be 3mm diam, comes out about 1mm.
Any ideas about how best to fix the part?
