Silicone extruder
Posted by joqnelson
Silicone extruder
April 23, 2013 05:52PM
We are making an extruder for silicone to work with the Makerbot Replicator 2. We designed a setup using a plunger and a 10oz cartouche thanks to the info on this forum.
We want the step motor to be controlled directly from the mother board (I switched polarity so the threaded rod turns correct direction). Is there a female coupling that will connect the motor power from the motherboard to the Nema 17 that powers the extruder (see pic)? They are identical 6 wire ports with 4 wires attached, 26AWG.
Can anyone recommend a supplier?
Thanks,
Jo
VDX
Re: Silicone extruder
April 24, 2013 02:15AM
Hi Jo,
this tools are named dispensers, not extruders winking smiley
Maybe you can find here some ideas for fixing and feeding - [reprap.org]
If you can't find the correct plugs, then use the Molex plugs used for powering CD/HD-drives (to find in old/outsourced PC's) or cut+solder the wires directly ...
Viktor
Aufruf zum Projekt "Müll-freie Meere" - [reprap.org]
April 25, 2013 04:44PM
Thanks, Victor.
Got the parts I needed from DigiKey, I'll post pictures when it progresses more.
Extruder...my mind is still stuck on our last invention:
[paintantsstudio.blogspot.com]
Jo
