Hi There,
I'm currently testing a simple syringe extruder loaded with Gallium Indium alloy. It should be perfect albeit slightly expensive for printing 3d circuitry. I've run into a problem with slic3r, I'm trying to set a crazy extrusion multiplier of 0.041 for my syringe extruder, it's on a multi-material mendel so I can't set this in firmware!
Slic3r is completely ignoring that setting. I've tried some wildly different values and had a look in the Gcode and it hasn't affected the E values at all!
Does anyone know if this is a bug or deliberate feature in slic3r?
Also does anyone have any ideas how I can generate multiple extruder gcode with one extruder setup very differently to the other?
Cheers for any help,
Pete
Edited 1 time(s). Last edit at 08/10/2013 05:09AM by PeteBlackerThe3rd.
