Gen7 & 644PA @ 20Mhz February 28, 2012 03:13PM |
Re: Gen7 & 644PA @ 20Mhz February 28, 2012 05:44PM |
I also purchased an STK500 development board so that I could program a bootloader on the chip.
If I insert a 20Mhz crystal into the board, set it to use the external reference - as SOON as I set the fuses to use the external crystal reference ( L:0xF7 H:0xDC E:0xFC ), the chip becomes completely unresponsive.
If I change the jumper back to use an internal clock reference, it runs, but the usart speed is all messed up.
When not using an external reference, the programmer seems to work fine. I can program a bootloader, but I can only program arduino programs with the STK500 using the ISP - not through the chip's direct serial port - I assume because the baud rate/timing is screwed up.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Gen7 & 644PA @ 20Mhz February 28, 2012 06:17PM |
Re: Gen7 & 644PA @ 20Mhz February 28, 2012 06:25PM |
Re: Gen7 & 644PA @ 20Mhz February 28, 2012 07:45PM |
Re: Gen7 & 644PA @ 20Mhz February 28, 2012 08:10PM |
Re: Gen7 & 644PA @ 20Mhz February 29, 2012 05:34AM |
Perhaps this should be the default settings listed on the Gen7 1.3.1 page for bootloader instead of 0xF7?
Re: Gen7 & 644PA @ 20Mhz February 29, 2012 10:40AM |
Re: Gen7 & 644PA @ 20Mhz March 20, 2012 10:41AM |
Re: Gen7 & 644PA @ 20Mhz March 21, 2012 04:26AM |
Re: Gen7 & 644PA @ 20Mhz March 26, 2012 01:23PM |
Re: Gen7 & 644PA @ 20Mhz March 30, 2012 03:33PM |
Larasius
Re: Gen7 & 644PA @ 20Mhz October 18, 2012 06:34PM |
