Generation 7 Spring Festival April 14, 2012 08:28PM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Generation 7 Spring Festival April 18, 2012 01:37AM |
Re: Generation 7 Spring Festival April 18, 2012 08:56AM |
Re: Generation 7 Spring Festival April 23, 2012 10:59AM |
Re: Generation 7 Spring Festival April 25, 2012 09:01AM |
Re: Generation 7 Spring Festival May 03, 2012 10:12AM |
Re: Generation 7 Spring Festival May 04, 2012 04:29AM |
Re: Generation 7 Spring Festival May 04, 2012 10:07AM |
Admin Registered: 14 years ago Posts: 2,569 |
Re: Generation 7 Spring Festival May 10, 2012 09:12PM |
Re: Generation 7 Spring Festival May 11, 2012 05:49AM |
Re: Generation 7 Spring Festival May 11, 2012 12:28PM |
Re: Generation 7 Spring Festival May 12, 2012 08:09AM |
Re: Generation 7 Spring Festival May 14, 2012 08:29PM |
Re: Generation 7 Spring Festival May 14, 2012 08:46PM |
Re: Generation 7 Spring Festival May 19, 2012 04:52PM |
Re: Generation 7 Spring Festival May 20, 2012 05:24AM |
Q: Why use the IRFZ44N MOSFET?
Q2: When using a 10 ohm resistor between the Arduino and the MOSFET, aren't you pulling 500 mA from the output pin?
This is why I added a transistor to drive the FET with 12 volts and higher currents while the Arduino only has to push the transistor (@ 12 mA). The downside is that I effectively inverted the signal.
Re: Generation 7 Spring Festival June 03, 2012 10:20AM |
Re: Generation 7 Spring Festival June 03, 2012 04:31PM |
Re: Generation 7 Spring Festival June 07, 2012 04:02AM |
Re: Generation 7 Spring Festival June 07, 2012 05:57AM |
Re: Generation 7 Spring Festival August 12, 2012 09:29AM |
Re: Generation 7 Spring Festival August 12, 2012 02:44PM |
Re: Generation 7 Spring Festival August 12, 2012 03:46PM |
