Gen7 1.2 -> Heatbead Kills Firmware?
Posted by steven85
October 20, 2012 01:13PM
Hello Guy's,
i trying to builde my prusa mendel for 6 months now ... and is still not not finished ... and now next big Problem and i don't have a clue ... maybe somebody can help me:
I have a Gen7 1.2 Board (ATMEGA644) with Teacup Fimware (i couldn't get the Repetier firmware running, and im still testing)
I'M Using the Serial Port of an older Notebook and a RS232 - TTL Converter from Pollin with a max232 on it. (this part gets intressting later)
Now i got that far that i could manuall move all 3 axis with repetier host Software. That is working.
But now if i connect the heatbed and turn the heat on in the repetier host the Boad Stuck:
Heatbet and Extruder LED's start to blink.
If i turn of power supply (atx pc) and disconnect the heatbed and turn on again
it's the same: Heat1 and Heat2 Led's blink.
i cannt move any axis.
if i reupload the Firmware over serial connection i can move the axis again, and the blinking hase gone.
The bootloader seems to be still alive as firmware upload ist possible.
Now if i connect a 6 ohm Power Resistor to the Heatbed connecort i can turn on the output, and the resistor gets hot.
I can turn off, and on again. No Troubles.
The Heatbed itself has 1OHM. Is That ok?
Does Anybody have an idea on how to fix this? Is there a Problem with the Heatbed (to less resistance? or something with the electronics? Or Maybe just the Firmware? Or the PSU?
Another Funny thing is: If i Remove the ATMEGA and i Disconnect the Serial Connector of the Notebook, the steeper motors start to move slowly.
It seems to be a grouding problem: The RS232 - TTL Converter is connecte to the +5 and GND of the Gen7 board.
I Can disconnect RX/TX and +5 nothing happens. But i'v i remove GND Stepper Motors start to move.
This only Happens if no ATMega is present.
Don't know if this is a problem or normal behaviour ?
Thanks for Reading.
Stefan
Re: Gen7 1.2 -> Heatbead Kills Firmware?
October 20, 2012 04:53PM
Have you set your fuses to turn on the brown-out-detector? Without BOD, simply turning off the power supply can be sufficient to let the ATmega run havoc and reprogram its self.
Without the ATemga, a Gen7 board is just a bunch of disconnected tracks, ready to receive whatever radiation flys around winking smiley
Regarding firmware I'd recommend to start with Teacup. It has fewer features, but also fewer options for misconfiguration (and guessing by the posts in this forum, fewer bugs).
October 20, 2012 05:02PM
Hello Traumflug,
HI I've set the H-L and E fuse acording to the bootloader upload Secion in the wiki.
But i was using avr-studio since I'M on windows and i use the avr dragon.
is this ok?
could the voltage drop be the problem? Should i try a different (more powerfull) psu?
thanks for your reply
regards
Stefan
October 20, 2012 05:08PM
Look for bootloader upload and/or fuses settings on the newer wiki pages, like that for Gen7 v1.4.1. Early Gen7s suffered this BOD problem, too and I forgot when it was fixed.
October 20, 2012 05:11PM
HI,
i just checked with a fuse calculator:
i programmed L-Fuse with 0xF7 as the wiki said.
But for brown i out i seems like a i would need a l-fuse 0xB7 ?
October 21, 2012 04:06AM
Hello I just checked Fuses and everything is ok.
Now i tried a different PSU. Yesterday i was using a "always on" PSU (with the ATX power on cabel shorted).
Now i'M using a normal PSU. And everytime i connect the heatbed eo either heater 1 or heater two
the psu turns off. Even if the heater is disabled.
Any ideas?
regards
Stefan
October 21, 2012 06:27AM
Your PSU likely needs a load on the 5V rail. Many PC PSUs have this requirement: [reprap.org]
October 21, 2012 07:57AM
HI just tried to put a 12v lamp on the 5v+ rail.
blub lights a little, but power suplly still turns off.
I've i use a 6ohm power restistor instead of the heatbed psu does not turn off?
any idea?
regards
Stefan
October 22, 2012 05:38AM
Is this a question or a comment? It's possible to connect the extruder heater to the heated bed connector. If that works it looks like your PSU is overloaded when turning on the heated bed. To confirm you can connect the heated bed directly to the 12V rails of the PSU.
October 23, 2012 08:34AM
Hello Traumflug,
that was a comment. Looking at this, the board should basicly work.
and the PSU is maybe be the problem.
I will try to connect the heatbed directly to the PSU, simple but clever idea (hätt ich selbst dauf kommen können winking smiley
Thanks for your reply.
regards
Stefan
October 27, 2012 04:15PM
Hello Traumflug,
i just tried to to connect the heatbed directly to the psu -> that is working.
I now change the Setup a littel -> now i'm only using the 4 Pin Molex connector. -> thte Power Supply is always on.
I now also locked the "application part of the ATMEGA Rom" with the Lockbit. -> now i do not lose the hole software after connecting the heatbed.
But i still doesnt work as is should: If i connect the heatbed either to heater one or two the AT Mega crashes.
In the repetier host Software i see serial com errors.
If the heater was turned on before connecting the heatbed it stay's on and the heatbed gets warm but the atmega isnt responding anymore. (cant send a commad)
Something is crashing the atmega, but i have no clue what?
any ideas?
regards
Stefan
October 28, 2012 07:01AM
Is it possible 5V supply voltage goes down when turning on the heated bet? If 5V SB goes below 4.3V, the brown out detector kicks in and resets the ATmega. Please measure the supply voltage of the ATmega. It's the pin left of the center in the row towards the serial connector: [reprap.org]
October 28, 2012 02:18PM
Hello Traumflug,
i tried to use external 5V Voltage, suplied by batteries and a Voltage regulator.
That does not solve the problem.
Its very strange. If i connect the heatbed the board isnt controllable with the host software.
But if i leave the heatbed connected it the heater led turns on and the heatbed starts warming up.
an after alle the heater 1 led starts blinking ...
But i cant turn it off by the host software.
it seems to be related to the resitance of the heatbed (1 ohm) cause as is said before if i connect a 6ohm resistor it works.
Or the heatbed is causing some freaking interferences?
alltought this problem is driving me crazy, i would be very intressting to find the problem smiling smiley
regards
Stefan
October 28, 2012 03:04PM
Intressting fact:
If i connect heatbed -> heater turns on (led goes on, heatbed gets warm)
if i now REMOVE the hole ATMEGA -> heatbed still on ...
NOW i totaly confused.
regards
October 28, 2012 03:47PM
ok ...
If i connect heatbed to heater 2 -> heater 2 on -> remove at mega -> heater 2 led dims down a little
AND Heater 3 led turns on.
Now i connect heatbed to heater 3 -> heatbed gets warm -> heater 3 stays on -> even atmega is removed.
I cann turn the power suply off and on again (+5V led turns off) -> heater 3 still heating.
alltought atmega is still removed.
If i Meassure pin 40 of the atmega socket against ground i can see a little voltage wich is dropping fast -> after that
heater 3 led turns off.
Soooo the Problem seems to be realted so some capacity ? but i have no clue where this is maybe comming from ...
regards
October 29, 2012 06:06AM
That's expected. If you remove the ATmega, the MOSFET input is unconnected and picks up random electromagnetic noise. There's no point in removing the ATmega.
And what is this "blinking"? When the firmware (BTW., which one are you using?) heats the bed and the bed reaches temperature, the heater ges on and off, but this can hardly be seen as "blinking".
October 29, 2012 06:58AM
Hello,
i know that thers no real point in removing atmega but I'm expirementing to maybe stumble across a solution.
do you really think the "noise" could turn on the Transistor?
If i meassure pin 40 to ground i see 2 nano farrad.
And if i remove the ATmega -> heatbed is on -> i meassuere pin 40 to ground the heater turns off and stays off !
Can this 2nf cause the trouble?
regarding the blinking: the led's sometime really blink (half second on half second off) I'm using teacup.
BTW: I send you an e-mail regarding Gen7 Parts.
regards
Stefan
October 29, 2012 01:36PM
Are you sure you've uploaded a firmware at all? The only really blinking stuff I'm aware of it SetupTest.pde, which helps setting up the serial connection but isn't helpful for much else.
