Heat bed with Gen6 pre-deluxe
Posted by miro87043
March 28, 2012 01:39AM
Hello!
Does anybody know if there is any way to add support for a heated bed on Gen 6 electronics? If not, is there an easy way to control heated bed without using the printers electronics. I'm using MK1 Heat bed for Prusa and would like it between 50-70c for PLA.
Thanks!!!!!!
Re: Heat bed with Gen6 pre-deluxe
May 16, 2012 06:14PM
Did you ever get an answer on this? I have one lying around that I'd love to dust off and put to good use!
May 16, 2012 07:14PM
Yes there is a way. If you've got around $40 you can do it pretty easily.
Check my blog. Schematic and code is there.
- akhlut
Just remember - Iterate, Iterate, Iterate!
[myhomelessmind.blogspot.com]
May 17, 2012 04:23AM
Here's a switch suitable to drive a heated bed: [reprap.org]
Now we need an Gen6 owner who figures out where to connect the signal pin. smiling smiley
November 14, 2012 04:40PM
Hi, I'm in that case I have a Gen6 board and a heatbed Mk2a, and looking for a solution to have the heatbed... heating 50-60°C smiling smiley.
I've read the SevenSwitch wiki page and it is unclear for me how to get the Gen6 working with it sad smiley.
And I imagine it would require firmware mods...
A solution without using the printer electronic would be fine.
I wonder if the heatbed would work with a Pulse Width Modulation, setting the temperature directly via width modulation.
With a manual command and direct temperature indicator, that could be fine.
[I'm a reprap noob...]
November 15, 2012 07:09AM
As with any soultion you need to find a signal pin on this board. You have the board, so you're much better in finding that.
November 15, 2012 02:01PM
I don't really understand what you mean Traumflug.
The only pin available is I2C. Pins used by a Gen6 are available to everybody and the same for all Gen6 no ?
Is it possible to control SevenSwitch with I2C, and control temparature this way without any firmware mod ?
November 16, 2012 07:22AM
I2C pins can be used as generic digital I/O pins, so yes, you can use these pins.
November 16, 2012 11:51AM
Ok. Thank you for this answer.
June 22, 2013 07:45AM
I've got this working if anyone's interested!!! [forums.reprap.org]
