ARM variant electronics July 20, 2012 01:55PM |
Host CPU card July 20, 2012 03:02PM |
Re: ARM variant electronics July 22, 2012 12:18PM |
Re: ARM variant electronics July 23, 2012 06:26AM |
(8.95 EUR, Cortex-M3 @ 72MHz, 42 IO ) ***Only has 32 kB Flash, 8kB RAM
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: ARM variant electronics July 23, 2012 04:31PM |
The LPC1758 has 512K Flash and total of 64K RAM, so we are somewhat overspecced. We allocate 64KB just for the USB bootloader, I think it actually uses about 15K.|
Re: ARM variant electronics July 23, 2012 06:06PM |
Re: ARM variant electronics July 24, 2012 01:55AM |
Re: ARM variant electronics July 24, 2012 05:55AM |
1. Stick with existing DIP ATMega solution (Gen7). This has enough power to do the job, can accept SD cards via SPI. It's not fancy, it's not expensive, it gets the job done. (Perhaps Traumflug can elaborate on the minimum BOM cost of this solution)
Re: ARM variant electronics July 24, 2012 11:30AM |
Re: ARM variant electronics July 24, 2012 04:19PM |
Re: ARM variant electronics July 24, 2012 04:29PM |
Re: ARM variant electronics July 24, 2012 04:52PM |
Re: ARM variant electronics July 24, 2012 05:15PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: ARM variant electronics July 24, 2012 08:43PM |
But there are better processors in sight.
Re: ARM variant electronics July 25, 2012 12:42AM |
Re: ARM variant electronics July 25, 2012 05:31AM |
SOIC packages are easily hand-solderable.
Your design uses carrier boards for SMD motor drivers.
So makers depend either on someone else to program that bootloader or a company to ship it to them preprogrammed.
Re: ARM variant electronics July 25, 2012 05:52AM |
Re: ARM variant electronics July 25, 2012 12:03PM |
Re: ARM variant electronics July 25, 2012 02:31PM |
Re: ARM variant electronics July 25, 2012 03:09PM |
Re: ARM variant electronics July 25, 2012 05:32PM |
But as far as ease of manufacture goes, I want to understand your reasoning on carrier boards. I don't understand why chips are okay, but carrier boards are not. That seems to me like an awfully arbitrary line to draw. What's the reasoning behind it? In the Reprap parlance, why is an ATmega644 a vitamin and an LPCXpresso not a vitamin?
Not everything bad, though, a year after the above, Gen7 apparently has found it's place. Not because it's faster, not because it's cheaper, mostly because it's the easiest to do DIY.
Re: ARM variant electronics July 25, 2012 05:55PM |
Re: ARM variant electronics July 25, 2012 06:20PM |
Re: ARM variant electronics July 27, 2012 12:47PM |
Re: ARM variant electronics August 01, 2012 03:40AM |
Re: ARM variant electronics August 10, 2012 01:58PM |
Re: ARM variant electronics September 11, 2012 09:26AM |
Re: ARM variant electronics October 01, 2012 05:08PM |
Re: ARM variant electronics October 02, 2012 04:49PM |
