1284 instead of 1284P ?
Posted by terramir
May 26, 2013 07:48PM
I accidently ordered a 1284 instead of an 1284P is there anyway to modify the support files inorder to make it work I got the 1284P bootloader loaded with a parallel port just by changing the id in the avrdude configuration but what else do I have to change and will it actually work?
terramir
Re: 1284 instead of 1284P ?
May 26, 2013 08:10PM
As far as I'm aware, the P indicates that it will operate at a lower voltage and has slightly different BOD behavior...neither should matter for the purposes of a Gen7 board, so changing the signature should be sufficient.
May 26, 2013 09:15PM
got the bootloader loaded, but then I got some odd behavior the program (marlin won't load it's hangs around forever and then gives me a timeout error.
don't exactly know what is going on if I knew I would be up and running with my second board.
I just ran it again I think I'm programming the fuses wrong or when I load the bootload the fuses get changed to something the 1284 can't hack or something
Or some weird problem could use some troubleshooting help what fuses should I use with the 1284 vs the 1284p with marlin?
Getting an stk500 timeout error I dunno what this is due too but it's happening even with the test firmware confused smiley
go figure
terramir
Edited 1 time(s). Last edit at 05/26/2013 09:29PM by terramir.
May 26, 2013 09:48PM
even tried it with a real ftdi chip instead of the cheap crappy serial connection no dice going wrong somewhere
terramir
May 27, 2013 02:29AM
It might be worth a shot to just try burning a hex file directly to rule out any serial comms problems. Turn on the verbose output in the Arduino preferences, load the test sketch from github and click "Verify". Locate the output folder for the .hex file, and burn that hex file as you would the bootloader (It shouldn't overwrite the bootloader). If it works properly, you have a serial problem. If it doesn't, my next guess would be either the crystal or the fuse settings.
Edited 1 time(s). Last edit at 05/27/2013 09:29PM by Rezer.
May 27, 2013 03:49AM
I seem to have another problem I just verified that it wasn't a problem with my board using a 664P worked fine but only with the 0.23 arduino ide.
I tried flashing the 1284 with the 1284p firmware from with-in 0.23p and the compliler puked all over the place
But flashing even the 664p from 1.0.1 is not happening I got a 20 mhz crystal and well I dunno what to do if 1.0.1 gets stuck 1.0.4 20 mhz bootloaders are supposedly broken but the 16 mhz on the 1.0.0 and 1.0.1 but not the 20 mhz but I can't flash with the 1.0.1 then I'm sorta up shit's creek, maybe that rumor is untrue I'll try using 1.0.4 and the 20mhz ones and see if it works if it doesn't I'll ask traumflug for 1284 (no P ) support files.
terramir
May 27, 2013 07:22AM
Arduino IDE before 1.0 didn't know about the 1284(P) Atmegas, so you won't have much success with that.
This trouble with the 20 MHz Gen7 bootloaders turned out to be a problem with Windows 64-bit. Somehow this OS refuses to work with the MCP2200.
May 27, 2013 09:31PM
Well, it works for some of us at least...running 64 bit windows 7 myself and haven't had any problems communicating with the board.
May 27, 2013 10:55PM
well then I'm try the 1.04 version of arduino later and see if that will get it going but honestly I dun have a clue yet
terramir
May 28, 2013 07:37AM
Undoubtly I'm keen on finding out on what makes the difference. smiling smiley
Did you install a more recent driver?
May 28, 2013 09:33AM
traumflug anyway to make a bootloader for the 1284?
I dunno seems like there fairly the same chip
Correct me if I'm wrong there
terramir
May 28, 2013 09:19PM
I'm not sure to be honest, I installed the 64 bit driver from the mcp2200 product page and everything has "just worked". I can give more specifics on which version of the driver I have installed when I get home.
> 1284?
> terramir
Your problem isn't related to the bootloader hex file, the 1284 and 1284p are functionally identical as far as the bootloader is concerned. The only reason the 644 and 644p have slightly different bootloaders is because the 644p has an additional UART; the 1284s have no such differences. Just changing atmega1284p to atmega1284 in boards.txt is all that is needed to use the arduino ide with an atmega 1284, which it sounds like you've already done. Your problem lies somewhere else, especially if it's really being that finicky with a 644p as well.
May 29, 2013 06:06AM
think I tracked down an issue. will post a separate post on this though since I got the firmware uploaded with a different board.
May 29, 2013 06:31AM
Actually, it's just the signature, because it would be safe to ignore the second UART on the (P). Anyways, thanks for the explanation.
May 29, 2013 12:33PM
Really? I didn't realize the signature was contained in the bootloader itself...my bad. Should still work though, right?
Oh, and I checked the mcp2200 driver version on my windows 7 64 bit machine...it was 1.2 (5.1.2600.3), and I uninstalled it and plugged the board back in. It automagically pulled 1.3 (5.1.2600.7) from windows update and still works fine *shrug*. I have UAC turned off on my machine, unsure if that would make a difference.
May 29, 2013 03:51PM
Yes.
And thanks for the driver info, added that to the wiki.
