Gen7 - Impossible to upload firmware May 19, 2013 11:57AM |
Re: Gen7 - Impossible to upload firmware May 20, 2013 12:23AM |
Re: Gen7 - Impossible to upload firmware May 20, 2013 05:15AM |
Re: Gen7 - Impossible to upload firmware May 20, 2013 06:28AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Gen7 - Impossible to upload firmware May 20, 2013 12:11PM |
Re: Gen7 - Impossible to upload firmware May 21, 2013 05:11AM |
Re: Gen7 - Impossible to upload firmware May 21, 2013 07:26AM |
Re: Gen7 - Impossible to upload firmware May 22, 2013 07:30AM |
any pointers or pit falls I need to watch out for in WinXP?
Re: Gen7 - Impossible to upload firmware June 07, 2013 02:42AM |
Re: Gen7 - Impossible to upload firmware June 09, 2013 09:46PM |
Re: Gen7 - Impossible to upload firmware June 10, 2013 02:30AM |
Re: Gen7 - Impossible to upload firmware June 16, 2013 05:23AM |
Re: Gen7 - Impossible to upload firmware June 17, 2013 07:22AM |
using the programmer it is much easier to upload the firmware and somewhere in the process I figured out that the "fuse" for the 1284pu differ form the fuse for the 1284p-pu.
Re: Gen7 - Impossible to upload firmware July 04, 2013 03:13PM |
Re: Gen7 - Impossible to upload firmware July 04, 2013 04:31PM |
Re: Gen7 - Impossible to upload firmware July 04, 2013 07:38PM |
Re: Gen7 - Impossible to upload firmware July 05, 2013 05:47AM |
I tried reinstalling the bootloader as per the wiki using my usbtiny.
Re: Gen7 - Impossible to upload firmware July 05, 2013 06:47AM |
Re: Gen7 - Impossible to upload firmware July 05, 2013 07:51AM |
Re: Gen7 - Impossible to upload firmware July 06, 2013 07:11AM |
Re: Gen7 - Impossible to upload firmware August 05, 2013 04:46PM |
Re: Gen7 - Impossible to upload firmware August 06, 2013 06:06AM |
Does the boot loader process set up a baud rate for the ATmega 1284?
The baud rate in the 2200 configuration utility is set to 19200.
Re: Gen7 - Impossible to upload firmware August 09, 2013 10:13PM |
Re: Gen7 - Impossible to upload firmware August 10, 2013 07:14AM |
the only thing that seems to be working is the PSU kicks on and the bottom right green led lights up and then a few seconds later it turns off again.
Re: Gen7 - Impossible to upload firmware August 12, 2013 11:41PM |
Re: Gen7 - Impossible to upload firmware August 13, 2013 06:47AM |
Re: Gen7 - Impossible to upload firmware August 13, 2013 04:28PM |
Re: Gen7 - Impossible to upload firmware August 13, 2013 06:38PM |
Re: Gen7 - Impossible to upload firmware August 14, 2013 08:55AM |
I thought once you uploaded the boot loader and locked it, it would stay on there until you erased the entire memory.
I did check all the voltages and found that the Tx pin is supplying 5V to pin 14 of the Atmega.
Re: Gen7 - Impossible to upload firmware August 19, 2013 08:42AM |
