Fan support?
Posted by Phizinza
Fan support?
January 18, 2013 03:59AM
Would it be possible to use one of the unused ATmega pins on Gen 7 running Teacup firmware as a fan controller pin?
Re: Fan support?
January 18, 2013 06:04AM
indeed! You can't power the fan directly from that pin but with a circuite similar to the heater controll there is no problem doing that.
Re: Fan support?
January 19, 2013 12:11AM
Could the pin power a small relay?
Or does it control, not power? Like control a MOSFET?
Re: Fan support?
January 19, 2013 08:42AM
I am assuming your fan is a 12V DC type.
Even a small relay I would want to control via a transistor. This is quite simple if you don't mind the clicking and don't want PWM.
Using a MOSFET instead of a transistor is almost as simple and is generally better. The trick is to find a "logic level" MOSFET that is commonly available and has a low enough resistance at 5V. My stock favourite is currently IRLB8743, which is overkill for a fan but will work.
A google search for "avr relay control" or "avr mosfet control" provides plenty of examples.
Re: Fan support?
January 19, 2013 04:44PM
Thank you both. Very helpful.
Re: Fan support?
January 19, 2013 06:27PM
The SevenSwitch [reprap.org] is a small board implementing the above. Maybe overkill already, but I think having this flowback diode is essential when running coil-based devices, i.e. an DC motor.
Re: Fan support?
January 25, 2013 04:55AM
bobc Wrote:
The trick is to
I can't find one of those near me or on the internet in Australia. Would this work? [www.jaycar.com.au]
Re: Fan support?
January 25, 2013 11:02AM
That looks almost ideal, I would add a flyback diode as Traumflug suggested. For a small fan you might get away with it, but MOSFETs can be quite sensitive to the "wrong" voltage.
Maybe also try RS [australia.rs-online.com]
