Gen 7 heat bed connector melted?
Posted by Phizinza
January 24, 2013 01:31AM
Hi, I have a 1.3.1 gen 7 board. The heatbed lost connection and there was a burning smell from the board. After closer inspection I found the white plug has melted through and the pin isn't making connection anymore.. Is this a known problem or is it the 34 degrees C ambient temperature I am printing in causing heat issues with the board?
Suggestions for larger plug or more heat resistant plug?
Re: Gen 7 heat bed connector melted?
January 24, 2013 07:27AM
This connector is very close to it's capabilities, so a bit dirt can make the connection poor enough to make it overheat.
- Make sure the crimp connectors are clean and soldered to minimize electrical resistance.
- If this still doesn't work, consider a screw terminal. The holes in the PCB are already there.
January 24, 2013 07:28AM
Do you mean the connector for the power source or the output connector?
In my case i use screw terminals. They should work up to 10A.
January 24, 2013 05:26PM
Output from the board to the heat bed has melted.
I'll have to get a screw terminal as I soldered it and it is clean.
Thanks.
January 27, 2013 12:41AM
I used wires and a 12A spec two contact connector from radio shack, thinking about using screw terminals for the next board myself
terramir
May 28, 2013 10:29AM
I have had the same problem with my Gen7 board and heated bed connector. I would like to replace the present headers with screw terminals, but can't find any of the correct pitch (3.96 mm). I can find screw terminals with 3.81 mm or 4 mm pitch - but not 3.96 mm. Obviously using a 4 mm pitch header in this context wouldn't be any problem, but it seems slightly perverse (and might cause problems if there were a larger number of contacts).
I've tried Farnell and Radionics - digikey / mouser have too high postage costs / minimum orders.
P.S. The alternative heated bed connectors suggested on the Wiki ( [reprap.org] ) have the incorrect pitch. (I'll try to fix if I have time.)
Edited 1 time(s). Last edit at 05/28/2013 10:30AM by dslc.
Semi-commercial engineering | Reprap diary
May 28, 2013 12:01PM
gen7 1.3.1 has enough pad width that you could drill holes are a 5mm distance in order to put a screw terminal and replace the header in question.
Also look into upgrading ( cutting traces and adding wires in order to have the thermistors be powered my 5V vsb :p
terramir
May 28, 2013 09:49PM
I put screw terminal on the heatbed output, I also did the standby power mod for the thermistors. Not my only problem is I sometimes have a lose connection on the hotend. I've used chocolate block terminals to connect it, but even they are getting so hot it is melting a bit... Still, with this new lot of ABS I have I seem to be able to print it at 20degrees less, so not having as many problems with that.
May 29, 2013 06:34AM
While the difference between 4 mm and 3.96 mm is neglibile, there should also be holes 0.2" inches (5.0 or 5.08 mm) apart. Look from the bottom side, they're close enough to the 4 mm spaced ones to be covered by the header.
June 01, 2013 05:57PM
@Terramir: Cheers. I went with the 5.08mm as per your / Traumflug's suggestion and have a safer electrical setup with 17.5 A screw terminal headers as s result.
@Traumflug: You're quite right: the holes are indeed there (I'm embarassed I missed them). The only catch is that I needed to widen the diameter of the holes to accept the through-hole leads of my new headers. That was no big deal though - a 1.2mm drill bit did the trick in my case. Good job and thanks for your help!
